i hv recently did a circuit with a driver and two motors,for driver ic input volt=9,dc motor=6v,when i start the arduino both motors hav some starting trouble,and the ic got heated up faster,wat to do?
rko111:
wat to do?
Start by posting the circuit with details of "the ic", and the sketch.
this is the circuit i have used
The L293D can drive upto 600mA. Perhaps your motors take more (nearly all do)? You
always need to know the stall current rating for a motor in order to select an appropriate
driver - also the nature of the power source is relevant.
If you have a multimeter you can measure the resistance at the motor terminals - less than
about 6 ohms and its unsuitable for the L293D (ie draws more than 1A at stall - the chip
maybe damaged beyond 1.2A, note).
