motor encoder and SMC G2 serial motor controller
I am controlling a single motorhttps://www.gobilda.com/5202-series-yellow-jacket-planetary-gear-motor-50-9-1-ratio-117-rpm-3-3-5v-encoder/
I am using a High-Power Simple Motor Controller G2 18v25
I am using a Nano. The issue I am having is the encoder is dropping steps. I can not control the position accurately.
I think the issue is coming from the software.serial sending the motor speed and direction. When I use just the encoder code with serial monitor the encoder steps are reading accurately.
Is this an issue where I need a different motor controller.
#include <SoftwareSerial.h>
#include <Encoder.h>
#define rxPin 3  // pin 3 connects to smcSerial TX  (not used in this example)
#define txPin 4 // pin 4 connects to smcSerial RX
// Change these two numbers to the pins connected to your encoder.
//   Best Performance: both pins have interrupt capability
//   Good Performance: only the first pin has interrupt capability
//   Low Performance:  neither pin has interrupt capability
Encoder myEnc(5, 6);
SoftwareSerial smcSerial = SoftwareSerial(rxPin, txPin);
// required to allow motors to move
// must be called when controller restarts and after any error
void exitSafeStart()
  smcSerial.write(0x83);
// speed should be a number from -3200 to 3200
void setMotorSpeed(int speed)
  if (speed < 0)
    smcSerial.write(0x86);  // motor reverse command
    speed = -speed;  // make speed positive
    smcSerial.write(0x85);  // motor forward command
  smcSerial.write(speed & 0x1F);
  smcSerial.write(speed >> 5 & 0x7F);
  // Initialize software serial object with baud rate of 19.2 kbps.
  smcSerial.begin(19200);
  // The Simple Motor Controller must be running for at least 1 ms
  // before we try to send serial data, so we delay here for 5 ms.
  delay(5);
  // If the Simple Motor Controller has automatic baud detection
  // enabled, we first need to send it the byte 0xAA (170 in decimal)
  // so that it can learn the baud rate.
  smcSerial.write(0xAA);
  // Next we need to send the Exit Safe Start command, which
  // clears the safe-start violation and lets the motor run.
  exitSafeStart();
long oldPosition  = -999;
int motSp = (0);
long setPosition =2850;
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
   if (newPosition > setPosition-50 && newPosition < setPosition+50){
    motSp = 0;
  else if ( newPosition < setPosition){
    motSp = 1000;
    else {
    motSp = -1500;
    setMotorSpeed(motSp);  // full-speed forward
Never Mind. I just needed to switch the pins for the encoder to pins with interrupt. Switched to pins 2 and 3. now reads much more stable. Still is not accurate at full speed tho.
did you also switch the software serial rxPin?
