Motor goes on forever!
So im trying to write some code for my robot for school. I got my two motors set up to turn and move forward, however when I run the commands it does not stop. This is the code that was provided to us, so I am not familiar with it. There is more than this but this is essentially what gets it to move. Also, when I change the parameters of mtrLeft or mtrRight, nothing changes, so it seems like it cannot read distance and just never ends. Help!
void loadCommandQueue() {
  cmdQueue.clear();
  cmdQueue.add(VEHICLE_START_WAIT);     // do not change this line - waits for start pushbutton
  cmdQueue.add(VEHICLE_START);          // do not change this line
  // Define robot movement speeds
  // Speed is encoder pulses per second.
  // There is a maximum speed.  Testing will be required to learn this speed
      cmdQueue.add(VEHICLE_SET_MOVE_SPEED,800);     // Speed used for forward movements
      cmdQueue.add(VEHICLE_SET_TURN_SPEED,650);     // Speed used for left or right turns
      cmdQueue.add(VEHICLE_SET_ACCEL,600);         // smaller is softer   larger is quicker and less accurate moves
        // Example list of robot movements
        // This block is modified for each tournament
      //cmdQueue.add(VEHICLE_FORWARD,4);
     cmdQueue.add(VEHICLE_TURN_LEFT);
     cmdQueue.add(VEHICLE_TURN_RIGHT);
     /*  cmdQueue.add(VEHICLE_FORWARD,10);
      cmdQueue.add(VEHICLE_FORWARD,5);
      cmdQueue.add(VEHICLE_FORWARD,425);
          // This MUST be the last command.
     cmdQueue.add(VEHICLE_FINISHED);
void loop () {
case VEHICLE_FORWARD :
      if (newCmd) {
        distance = ((long) cmdQueue.getParameter1() * (long) ENCODER_COUNTS_PER_REV / (long) MM_PER_REV);
        speed = speedFwd;
        mtrLeft.startMove(distance,speed);
        mtrRight.startMove(distance,speed);
        setMotorOutputs();
      if (mtrLeft.isStopped() && mtrRight.isStopped()) {
        setMotorOutputs();
        cmdQueue.next();
    case VEHICLE_TURN_RIGHT :
      if (newCmd) {
        distance = ENCODER_COUNTS_90_DEG;
        speed = speedTurn;
        mtrRight.startMove(distance,speed * -1);
        setMotorOutputs();
Posting snippets of code is against the Forum Guidelines. Please post your entire sketch.
And take a second look at your loop code.
You mis-coded or mis-wired motor ENABLE. Post your whole sketch, a circuit diagram, and a photograph of the wired project.
