Motor Help, PLEASE
Hello,
I am working on a project and would like to have a motor that runs on about 10-15 volts, any idea how fast that could go or how much weight it could pull?
thanks,
the project is a Dr-Who K-9 full scale model, (soon to be dalek later)
That depends on the motor. There are many to choose from but the
first thing you need to do is work out your torque, speed and power requirements.
Ok, thanks, ill get back to you on that
If you want pulling power and speed I'd suggest you look at the 24volt motors that are fitted to electric scooters. Something like one of these :
http://www.ebay.co.uk/itm/Electric-E-scooter-24-volt-150-wt-motor-brand-new-upgrade-X120-e10-x140-etc/231076950902?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D74%26meid%3D4833598195879507660%26pid%3D100005%26prg%3D1048%26rk%3D2%26rkt%3D4%26sd%3D231157329773%26
or visit your local wheelchair repair shop and see if you can pick up some motors from a scrapped wheelchair. The advantage of these is that they generally come with a gearbox fitted.
Thanks so much for the help :slight_smile:
