motor help
Does anyone know the equivalent part number for MAXON DC motor PT# 00.00-686? This is the DC motor used in the the Leica Rugby 100 self leveling laser transit for surveying. When I inquired at MAXON for a replacement for this part number, they told me it is a proprietary part you must call the manufacture. I then asked do they make a equivalent DC motor that is not proprietary and he said yes but could not discuss that item with me because I asked about the proprietary dc motor first.
Thank you for your assistance
TOPIC SPLIT
DO NOT HIJACK !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
The only solution I see if for you to contact Leica and ask about a replacement or refurbished part.
That there is the possibility of a non oem motor means that you should be able to google for a replacement.
You may have to give all the numbers seen on the motor at present for anyone top be able to do a "look up"
Also make sure it includes the correct sequence of numbers characters.
This might not be too helpful. As you likely realize Maxon's sales are probably 90% oem meaning the customer can customize nearly any characteristic of the motor. Two common customizations are mounting and shaft.
So before I went on a hunt for an exact replacement from Maxon's "retail" offering, I would check to see if they offer a motor of the same dimensions and "approximate" voltage.
