Motor interferes Servo
I finally had the first test run of my rc chopper control. It was not as promising as I hoped.
Steering the servos with the joystick worked, as did controlling the rotor throttle. Also the sensor data was received well on the netbook and it visualised perfectly.
Then i realised something strange:
When I increase the throttle above a certain value, the servos first start to jump around, and then move to one of their extreme positions.
If I disconnect the motors, the effect vanishes. So, I suspect the problem has an electronic source.
Where should I start troubleshooting?
Here are the relevant parts of the sketch. It didn't all fit into the post.
Chopper control. Replaces the receiver unit of an rc helicopter.
At first it provieds sensor data to a remote controlling unit while
executing the commands received over the bluetooth link.
#define USE_COMPASS
#define USE_ACCELERO
//#define USE_BARO
#define USE_DRIVEMOTOR
#define USE_RANGE_SCANNER
//#define USE_HELP_MSG
#include <Servo.h>
#include <Wire.h>
#ifdef USE_HELP_MSG
  #include <avr/pgmspace.h>
#endif
#include "Streaming.h"
#ifdef USE_RANGE_SCANNER
  #include "RangeScanner.h"
#endif
#ifdef USE_BARO
  #include "IntersemaBaro.h"
#endif
#ifdef USE_COMPASS
  #include "PID_Beta6.h"
#endif
// analog pins
static const uint8_t pinIRDist     =   3; // analog
//                                     4  // i2c SDA
//                                     5  // i2c SCL
// digital pins
//                                     0  // rx serial over bluetooth
//                                     1  // tx serial over bluetooth
static const uint8_t pinSensorPwr  =   2; // power for compass, accelerometer and barometer
static const uint8_t pinBaroMCLK   =   3; // the tone function used to generate the 34kHz signal interferes with pin 3 and 11, so it's best to use it directly
static const uint8_t pinBaroDOUT   =   4; // in  on the arduino
static const uint8_t pinMotorUpper =   5; // upper rotor throttle -> needs to be PWM
static const uint8_t pinMotorLower =   6; // lower rotor throttle -> needs to be PWM
//                                     7  // bluetooth reset, don't use!!!
static const uint8_t pinBaroSCLK   =   8; // serial clock for the barometer
static const uint8_t pinBaroDIN    =   9; // out on the arduino
static const uint8_t pinServoIrRng =  10; // servo for swaping the ir proximity sensor
//                                    11  // affected by the tone lib (don't use for PWM)
static const uint8_t pinServoFB    =  12; // servo for forward backward tilt
static const uint8_t pinServoLR    =  13; // servo for left right tilt
// i2c addresses
static const uint8_t addrCompas    = (0x42 >> 1);
static const uint8_t addrNunchuck  =  0x52;
  RangeScanner  rangescn(pinIRDist, pinServoIrRng);
#endif
#ifdef USE_BARO
  BaroPressure_MS5534C baro(pinBaroMCLK, pinBaroSCLK, pinBaroDIN, pinBaroDOUT);
#endif
#ifdef USE_DRIVEMOTOR
  Servo srvFrontBack;
  Servo srvLeftRight;
#endif
#ifdef USE_COMPASS
  double pidSetpoint, pidInput, pidOutput;
  PID myPID(&pidInput, &pidOutput, &pidSetpoint, 2, 5, 1);
#endif
bool          doSendSerial  = false;
bool          doSweepServo  = false;
size_t        loopDelay     = 100;
uint8_t       targetHeading = 0;
uint8_t       motorSpeed    = 0;
long          loopCounter   = 0;
size_t evalSerialCmd();
void   evalCmdStr(char *txt);
    pinMode(pinSensorPwr, OUTPUT);
    digitalWrite(pinSensorPwr, LOW);
    delay(200);
    digitalWrite(pinSensorPwr, HIGH);
    delay(200);
    Serial.begin(115200); // arduino bt has only this baud rate
    Wire.begin();         // join i2c bus as master
    pinMode(pinMotorUpper, OUTPUT);
    pinMode(pinMotorLower, OUTPUT);
    srvFrontBack.attach(pinServoFB);
    srvLeftRight.attach(pinServoLR);
#endif
    rangescn.begin();
    rangescn.setStepAngle(5);
    rangescn.setScanningRange(160);
    rangescn.moveToIdlePos();
#endif
#ifdef USE_ACCELERO
    Wire.beginTransmission(addrNunchuck);// transmit to device 0x52
    Wire.send(0x40);// sends memory address
    Wire.send(0x00);// sends a zero, requesting the first data
    Wire.endTransmission();// stop transmitting
    delay(100);
#endif
#ifdef USE_BARO
    baro.begin();
#endif
#ifdef USE_COMPASS
    pidSetpoint = 0;
    myPID.SetInputLimits (-180.0, 180.0);
    myPID.SetOutputLimits(-100.0, 100.0);
    myPID.SetMode(AUTO);
#endif
#ifdef USE_COMPASS
    Wire.beginTransmission(addrCompas);
    Wire.send('A');  // command sensor to measure angle
    // step 2: wait for readings to happen
    delay(10);                        // datasheet suggests at least 6000 microseconds
    // step 3: request reading from sensor
    Wire.requestFrom(addrCompas, static_cast<uint8_t>(2));       // request 2 bytes from slave device #33
    // step 4: receive reading from sensor
    int compassHeading = 0;
    if(Wire.available() >= 2)         // if two bytes were received
        compassHeading = Wire.receive(); // receive high byte (overwrites previous reading)
        compassHeading = compassHeading << 8;       // shift high byte to be high 8 bits
        compassHeading += Wire.receive();    // receive low byte as lower 8 bits
        compassHeading /= 10;
        compassHeading -= 90;  // mounting position on the board
        while(compassHeading < 0)
            compassHeading += 360;
        while(compassHeading > 360)
            compassHeading -= 360;
        if(doSendSerial)
            Serial << "CH" << _DEC(compassHeading);
#endif
while(Serial.available())
        evalSerialCmd();
    if(motorSpeed < 10)
        analogWrite(pinMotorLower, 0);
        analogWrite(pinMotorUpper, 0);
#ifndef USE_COMPASS
        analogWrite(pinMotorLower, motorSpeed);
        analogWrite(pinMotorUpper, motorSpeed);
#else // USE_COMPASS
        // calculate the speed for the two rotors with heading correction
        int headingDeviation  = targetHeading - compassHeading;
        while(headingDeviation < -180)
            headingDeviation += 360;
        while(headingDeviation > 180)
            headingDeviation -= 360;
        pidInput = headingDeviation;
        myPID.Compute();
        const int throttleDeviation = pidOutput - 50;
        int throttleLower = motorSpeed - throttleDeviation;
        throttleLower = max(throttleLower, 0);
        throttleLower = min(throttleLower, 255);
        int throttleUpper = motorSpeed + throttleDeviation;
        throttleUpper = max(throttleUpper, 0);
        throttleUpper = min(throttleUpper, 255);
        analogWrite(pinMotorLower, throttleLower);
        analogWrite(pinMotorUpper, throttleUpper);
        if(doSendSerial)
            Serial << "ML" << _DEC(throttleLower)
                   << "MU" << _DEC(throttleUpper)
                   << "HD" << _DEC(headingDeviation)
                   << "TD" << _DEC(throttleDeviation);
#endif // USE_COMPASS
#endif // USE_DRIVEMOTOR
    if(!strcmp(txt, "lon"))
        doSendSerial = true;
    else if(!strcmp(txt, "loff"))
    else if(!strncmp(txt, "th", 2))
        targetHeading = atoi(txt + 2);
    else if(!strncmp(txt, "ms", 2))
        motorSpeed = atoi(txt + 2);
    else if(!strncmp(txt, "fb", 2))
        srvFrontBack.write(atoi(txt + 2));
    else if(!strncmp(txt, "lr", 2))
        srvLeftRight.write(atoi(txt + 2));
#endif
    else if(!strcmp(txt, "swon"))
        doSweepServo = true;
    else if(!strcmp(txt, "swoff"))
    else if(!strncmp(txt, "swst", 4))
        rangescn.setStepAngle(atoi(txt + 4));
    else if(!strncmp(txt, "swrg", 4))
        rangescn.setScanningRange(atoi(txt + 4));
#endif
    else if(!strncmp(txt, "lode", 4))
        int newval = atoi(txt + 4);
        if(newval >= 10 && newval <= 1000)
            loopDelay = newval;
#ifdef USE_HELP_MSG
        prog_uchar helpstr[] PROGMEM =
            "\nIrServoRangeScanner\n"
            "'lon' send serial data\n"
            "'loff' stop serial data\n"
            "'swon' moving ir proximity sensor\n"
            "'swoff' stop moving ir proximity sensor\n"
            "'swst<nn>' angle deg per step\n"
            "'swrg<nn>' scanning range\n"
            "'th<nn>' desired compass heading\n"
            "'ms<nn>' motor speed for the rotors\n"
            "'fb<nn>' servo forward backward tilt\n"
            "'lr<nn>' servo left right tilt\n"
            "'lode<nn>' millisecs to sleep on loop\n"
            "'?'  for this help msg\n\n"
        prog_uchar *cptr = helpstr;
        char cc;
        while(cc = pgm_read_byte(cptr++))
             Serial.print(cc, BYTE);
#endif
        if(strlen(txt) && strcmp(txt, "?"))
            Serial.print("Invalid option: \"");
            Serial.print(txt);
            Serial.println("\"");
Try a decoupling the motor power source ( a search for Arduino motor decoupling should find plenty of hits)
The battery pack may also not be able to supply enough current to power 2 servos and 2 motors. But yeah, definitely try decoupling first.
