Motor is not rotating when operated via bluetooth
12V across the main supply, 9V across the motor that works and 0V across the one that doesn't. I have also checked the voltage supplies of the enable and the IN pins of the driver. The enable gives around 3-4 (since it's connected to a PWM pin for speed control) and the IN pin gives close to 5V.
Okay i"ll do that.
