Initial Position
When it starts up the Arduino has no means of knowing where the stepper motor is positioned - for example somebody might have moved it manually when the power was off.
The usual way to establish a datum for counting steps is with a limit switch. At startup the Arduino will move the motor until it triggers the switch. The Arduino will then regard that step position as step zero for the purpose of future position keeping.
I am not sure how to implement this. I am using a basic motor knob program. Trying to move the motor 45 deg fixed position. I not failing to determine its initial position. It should be 0 deg for 0 V and 45 deg for 5 V.
Can you tell me where am i going wrong.
#include <AccelStepper.h>
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
#define ANALOG_IN A1
stepper.setMaxSpeed(1000);
// Read new position
int analog_in = analogRead(ANALOG_IN);
stepper.moveTo(analog_in);
stepper.setSpeed(100);
stepper.runSpeedToPosition();
