Hi Guys,
I have set up a small system to count how many times I could activate a push button on a panel before it collapsed.
The button is guaranteed to 500K activations, but we experienced some collapsing long before that.
Thus I made a test
I used the following:
Arduino Uno
Adafruit Motor Shield
12DC motor with a short (3cm) metal arm
The pushbutton to be tested ( connected to pin 4)
12V 5A external power supply for the motor
The idea is to Start the Uno and loop through the following:
Set the motor running forward and forcing the mounted arm to hit the button on the table
When the button is activated, the motor stops and reverses
After 250 milliseconds , the motor stops and goes forward again
The loop is wrapped round a "watchdog" that stops the UNO when the button eventually breaks and saves to count to EEProm
Progress is showed on a LCD
The test has worked fine and we even counted more than 2 million activations before the button broke.
Success - and all is fine from that point of view.
But I am pussled by the behavior of the motor because the cycle is as follows:
Turn clockwise( forward) and hit the button
Turn counterclockwise approx 45 degrees
Turn counterclockwise approx 120 degrees
This cycle continues until the button breaks, i.e. 2 short burst and a long burst.
Why is the cycle uneven?
Is my code "uneven" or is it perhaps a hardware issue?
It has made no difference if I have had the Uno powered by USB, separate 12V, or 12V from the Motor shield
And here is the code
#include <Wire.h>
#include <EEPROM.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *myMotor = AFMS.getMotor(2);
#include <SoftwareSerial.h>
// Create a software serial port!
SoftwareSerial lcd = SoftwareSerial(0,2);
long Watchdog =millis();
long cycletime=millis();
long counter=0;
int fspeed=55;
int rspeed=55;
int run=4; // name of button to be tested on touchpad
boolean reversing=false;
const int MaxTimeWatchDog =700;
const int MaxCycletime=250;
counter= EEPROMReadlong(0);
AFMS.begin(); // create with the default frequency 1.6KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
myMotor->setSpeed(fspeed);
pinMode(run,INPUT_PULLUP);
lcd.begin(9600);
// Set up LCD
lcd.write(0xFE);
lcd.write(0xD1);
lcd.write(16); // 16 columns
lcd.write(2); // 2 rows
delay(10);
// set the contrast,
lcd.write(0xFE);
lcd.write(0x50);
lcd.write(200);
delay(10);
// set the brightness -
lcd.write(0xFE);
lcd.write(0x99);
lcd.write(255);
delay(10);
// turn off cursors
lcd.write(0xFE);
lcd.write(0x4B);
lcd.write(0xFE);
lcd.write(0x54);
// Clear screen
lcd.write(0xFE);
lcd.write(0x01);
delay(10);
// lcd.print(" ButtonBounce");
// delay(1000);
// lcd.print(" Idle ");
delay(30);
while ((millis()-Watchdog) < (MaxTimeWatchDog))
if( millis()-cycletime>MaxCycletime)
// lcd.println ("now in loop");
// lcd.println(cycletime);
myMotor->run(RELEASE);
delay(50);
myMotor->run(FORWARD);
cycletime=millis();
if(digitalRead(run)==LOW & !reversing)
delay(50);
myMotor->run(BACKWARD);
reversing=true;
counter++;
Watchdog=millis();
// Clear screen
lcd.write(0xFE);
lcd.write(0x01);
delay(10);
lcd.write(1);
delay(10);
lcd.print("Cnt: ");
lcd.print(counter);
// updatelcd;
if(digitalRead(run)==HIGH)
reversing=false;
// Clear screen
// If we get to here we are out of the while loop and have timed out
EEPROMWritelong(0,counter);
lcd.write(0xFE);
lcd.write(0x01);
delay(10);
lcd.write(1);
delay(10);
lcd.print(" Cnt: ");
lcd.print(counter);
lcd.print(" Stopped");
// updatelcd;
// Functions to read & write values to EEprom
void EEPROMWritelong(int address, long value)
//Decomposition from a long to 4 bytes by using bitshift.
//One = Most significant -> Four = Least significant byte
byte four = (value & 0xFF);
byte three = ((value >> 8) & 0xFF);
byte two = ((value >> 16) & 0xFF);
byte one = ((value >> 24) & 0xFF);
//Write the 4 bytes into the eeprom memory.
EEPROM.write(address, four);
EEPROM.write(address + 1, three);
EEPROM.write(address + 2, two);
EEPROM.write(address + 3, one);
//This function will return a 4 byte (32bit) long from the eeprom
//at the specified address to address + 3.
long EEPROMReadlong(long address)
//Read the 4 bytes from the eeprom memory.
long four = EEPROM.read(address);
long three = EEPROM.read(address + 1);
long two = EEPROM.read(address + 2);
long one = EEPROM.read(address + 3);
//Return the recomposed long by using bitshift.
return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
