Motor Project Help!
Hi guys,
So I am working on building an alarm clock that opens my blinds when the alarm goes off. I have the alarm clock all setup on my lcd (I am not using a shield just a plain old lcd) and it looks great, but the problem I ran into now is with the motor to open my blinds. I have a small servo motor, but that only rotates 180 degrees. The servo will not be able to rotate far enough for it to open and close the blinds all the way. I also have a small 6/9 volt Dc motor, but I can not figure out how to set it up and control the speed from my Arduino. I could use a stepper motor, but I don't know what parts other parts I would need to buy along with the steppermotor to make it run. I have an Arduino uno and pins 1,2,9, and 12 on Digital open to use for my project. So really my question is what motor should I use and how! I'm open to suggestions about my project, but someone please help!
A stepping motor driver:-
[driver](Pololu - A4988 Stepper Motor Driver Carrier)
You'll probably need to gear it down (or use pulleys, etc.) Typically, you'd use a DC motor and limit switches to tell it when to stop. If you wanted to do things like automatically open to 50% or 10%, then you'd use a stepper motor but you'd still need a limit switch or "home sensor" so the microcontroller knows where to start counting steps.
A DC motor requires a transistor or MOSFET driver, and since you want to reverse it you need an "H-Bridge" motor driver. With PWM into the motor driver you can also control speed but when you reduce speed with PWM you also reduce torque (the opposite of a gear or pulley system) and you probably won't be able to get it slow enough with PWM alone.
A stepper motor requires a stepper-motor driver.
What do you mean by gear it down? Would this Mosfet transistor [IRF520] work? I have also read that Diodes are needed with the dc motor to help prevent destroying the arduino so would this Diode [1N4007] work? I think i'll go with the dc motor, but I do not know how to wire it up. I know I am a newbie to all of this :confused: but thank you for the help!
What type of blinds do you have? Below are some previous discussions.
https://www.google.com/search?ie=UTF-8&oe=UTF-8&q=blinds&btnG=search&domains=http%3A%2F%2Fforum.arduino.cc&sitesearch=http%3A%2F%2Fforum.arduino.cc&gws_rd=ssl
Putting gears on the end of the motor to reduce the rotation speed. It will be too fast without.
However the problem with a DC motor is that you do not have the control over its position.
