Motor recommendation for viscous liquids
What kind of motors can I use to pump viscous liquids? I am looking for a mini size motor/pump.
Regards,
Amulya
this may help
you don't have to use the same supplier or product
Thank you for your response, Tom. This is helpful!
What is the liquid exactly ?
Knowing that would help greatly to define a suitable pump.
Also what voltages are available for the pump ?
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
The liquid will be soap and planning to supply the voltage using the battery.
Liquid soap comes in many viscosity so details would be appreciated.
Battery ?
1.5 volt 6 volt 12 volt 24 volt ?
Capacity ?
Rechargeable ?
I did not give you those links just for fun so use them then we do not have to drag details out of you as it becomes very tedious.
If you really want help then we need DETAILS !
Not meaning to sound harsh but sometimes a simple request can drag out for weeks and months without enough information.
