Good morning people of the forum need to build an elevator controlling motor rotation, I want you found 6 knobs, 3 to rotate the motor clockwise and so gain ground, and other 3 counterclockwise to lower each buttons, bring to a particular floor, utilze infrared sensors for this part.
I intend to go to any floor from the current floor.
Here the code:
/*Control de relay*/
int relay = 10;
int relay2 = 11;
int BotonDer1 = 9;
int BotonDer2 = 8;
int BotonDer3 = 6;
int BotonIzq1 = 7;
int BotonIzq2 = 3;
int BotonIzq3 = 12;
int botonp1 =2;
int botonp2 =4;
int botonp3 =5;
pinMode(relay, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(BotonDer1,INPUT);
pinMode(BotonDer2,INPUT);
pinMode(BotonDer3,INPUT);
pinMode(BotonIzq1,INPUT);
pinMode(BotonIzq2,INPUT);
pinMode(BotonIzq3,INPUT);
pinMode(botonp1, INPUT);
pinMode(botonp2, INPUT);
pinMode(botonp3, INPUT);
//PUSHBOTTON ARRANQUE DERECHO 1
if (digitalRead (9) == HIGH){
digitalWrite ( relay, HIGH);
digitalWrite ( relay2, LOW);
else if (digitalRead (2) != HIGH){
digitalWrite ( relay, LOW);
//PUSHBOTTON ARRANQUE DERECHO 2
if (digitalRead (8) == HIGH){
else if (digitalRead (4) != HIGH){
//PUSHBOTTON ARRANQUE DERECHO 3
if (digitalRead (6) == HIGH){
else if (digitalRead (5) != HIGH){
//PUSHBOTTON ARRANQUE IZQUIERDO 1
if (digitalRead (7) == HIGH){
digitalWrite ( relay2, HIGH);
//PUSHBOTTON ARRANQUE IZQUIERDO 2
if (digitalRead (3) == HIGH){
else if (digitalRead (13) != HIGH){
//PUSHBOTTON ARRANQUE IZQUIERDO 3
if (digitalRead (12) == HIGH){
