motor rotation limit
so this is what i have so far but i can't seem to get the motor to rotate once, stop by the means of a rocker switch then continue. i can only get it to stop
const int buttonPin = 4;
int val = 0;
  //Setup Channel A
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
  pinMode(buttonPin, INPUT);
  val = digitalRead(buttonPin);
  if (val == LOW) {
                           //forward @ full speed
  digitalWrite(12, HIGH); //Establishes forward direction of Channel A
  digitalWrite(9, LOW);   //Disengage the Brake for Channel A
  analogWrite(3, 255);   //Spins the motor on Channel A at full speed
  else {
  digitalWrite(9, HIGH); //Engage the Brake for Channel A
  delay (2000);        // delay for set amount of time
                        // then repeat the whole thing
What motor? What shield/controller? How are you measuring its position? What is the motor actually doing?
I think you need to move the 'delay(2000)' outside the else block. Also you should provide more circuit info.
It would appear that if you start the sketch with the motor positioned on the switch then the sketch just continues to run the stop code.
val = digitalRead(buttonPin); if (val == LOW) {
if val is already high then this code will never run. So - the motor runs until it trips the switch and stops, and if the switch is still tripped the motor will never start again.
i have a r3 motor shield on top of an arduino uno, the motor is a 3-12 volt motor with a gear box on it to make it run at 15 rpm. the position is measured by a roller tack switch. the motor as a 6in wheel on it with a hole cut in it to let an item drop
this is newest code i have
boolean lastButton = LOW;
boolean currentButton = LOW;
boolean switchon = false;
  //Setup Channel A
boolean debounce(boolean last)
  boolean current = digitalRead(buttonPin);
  if (last != current)
    delay(5);
  return current;
  currentButton = debounce(lastButton);
  if (lastButton == LOW && currentButton == HIGH)
   switchon = !switchon;
    lastButton = currentButton;
  digitalWrite(9, !switchon);   //Disengage the Brake for Channel A
should i use a interrupt to make this work instead or is that not necessary
bengrvr: i have a r3 motor shield on top of an arduino uno, the motor is a 3-12 volt motor with a gear box on it to make it run at 15 rpm. the position is measured by a roller tack switch. the motor as a 6in wheel on it with a hole cut in it to let an item drop
So what are you using to stop the rotation a roller track switch or a rocker switch or are you reffering to the same switch?
Is pin 12 used to communicate with a shield? I ask because of:
Surely you would reverse the order of this?
What about braking, are you using the DC braking of the motor itself or some other method?
this is what i have so far and it works to what i want
int val = 0;
  //Setup Channel A
    delay(5);
  return current;
  if (val == LOW) {
  else {
  delay (5000);        // delay for set amount of time
  if (val == LOW) {
  else {
