I make a line follower robot using Arduino Nano and TB6612FNG Motor driver. It is working but only issue is when the motor rotate manually that power goes to LED near 7805 regulator . please advice how should I manage to stop it
my reference schismatics is attached
I am using LM2695 regulator instead of the schismatics power supply
The obvious thing would be a diode in the Vboost line to stop the backflow of current but that may have side effects such as a too low Vboost, overheating diode, etc. This based on what I see in your schematic and the rather vague description of the problem so I may be very wrong here.
The schematic you post doesn't make much sense to me - especially components U4 to U8.
PA3040:
but only issue is when the motor rotate manually that power goes to LED near 7805 regulator . please advice how should I manage to stop it.
So are you saying that the motor is acting in a voltage and power generating mode?
Maybe you can add a switch of some sort… so that when you manually switch off power to your system (via a manual switch), then it doesn’t only switch off the power, but also disconnects whatever you want to disconnect…such as your motor. eg… DPST switch, or maybe DPDT switch.
