I need help about a system composed of a 2 channel relay module, an arduino and a microwave motor.
I have defined an digital IO to control the motor, and set two variables to turn on and turn off the drive. The problem is that sometimes when I turn on the motor, instead of running clockwise, it reverses the direction of rotation, and starts to run backwards.
What should I do to fix the direction of rotation of my motor, so that it only rotates clockwise?
Welcome back fs gonzaga, For clarification I assume we are talking about the stirrer blades. These are used to prevent hot spots. Most microwaves reverse each time the stirrer blades motor is started. Reversing vaires from model to model, sometimes it is mechanical, some times electrical and some are now electronic.
Sorry for that @gilshultz ! maybe the best choice is really try to find a DC motor, with similar specifications to the one i´m using today (5/6 rpm, and high torque)
