4711
March 9, 2021, 10:00am
#1
Hallo Gemeinde,
ich probiere gerade mit einem Motorshield einen DC Motor zu drehen, klappt auch.
Meine Frage, die Beispiele geben leider nicht viel her und die Library finde ich nicht am PC?
Ich kann den Speed, Forwärts, Rückwärts, Relaese ansteuern. Der Motor macht entsprechendes.
Wie kann ich abfragen, ob sich der Motor dreht, sprich ob er angesteuert ist?
myMotor.run ?
The original Adafruit Motorshield kit is one of our most beloved kits, which is why we decided to make something even better. We have upgraded the shield kit to make the bestest, easiest way to drive DC and Stepper motors. This shield will make quick...
http://adafruit.github.io/Adafruit_Motor_Shield_V2_Library/html/_adafruit___motor_shield_8h_source.html
Danke!
Include the required libraries
Make sure you #include the required libraries
#include
#include
#include "utility/Adafruit_MS_PWMServoDriver.h"
Create the Adafruit_MotorShield object
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
© Adafruit Industries https://learn.adafruit.com/adafruit-motor-shield-v2-for-arduino Page 54 of 67
Create the DC motor object
Request the DC motor from the Adafruit_MotorShield:
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
with getMotor(port#). Port# is which port it is connected to. If you're using M1 its1, M2 use 2, M3 use 3 and M4 use 4
Connect to the Controller
In your setup() function, call begin() on the Adafruit_MotorShield object:
AFMS.begin();
Set default speed
Set the speed of the motor using setSpeed(speed) where the speed ranges from 0 (stopped) to 255 (full speed). You
can set the speed whenever you want.
myMotor->setSpeed(150);
Run the motor
To run the motor, call run(direction) where direction is FORWARD, BACKWARD or RELEASE. Of course, the Arduino
doesn't actually know if the motor is 'forward' or 'backward', so if you want to change which way it thinks is forward,
simply swap the two wires from the motor to the shield.
myMotor->run(FORWARD);
4711:
Die Beispiele geben das her, was die Lib kann.
4711:
Die Library befindet sich im library-Ordner deines Sketchbooks, und wo das ist, siehst Du unter Datei->Voreinstellungen.
4711:
Der Motor dreht sich nur, wenn Du in gestartet hast. Du solltest also immer wissen, ob er dreht oder nicht.
Hallo,
oder den Motorstrom messen.
uwefed
March 9, 2021, 2:20pm
#4
Ob der Motor dreht gibt es mehrere Möglichkeiten:
Sehr sicher: Drehung durch Sensor (Lichtschranke, Magnetsensor) messen. eventuell Encoder (teurer)
weniger sicher: Motorstrom messen: Einige Treiber können einen Strommeßwiderstand zwischen Treiber und Masse haben. Strommessung auf dem Pluspol durch INA219B
noch weniger sicher: messen ob Spannung am Motor zB durch 2 Optokoppler.
Grüße Uwe
4711
March 10, 2021, 6:45am
#5
Morgen,
dh aus der Library bekomme ich das nicht raus, will nur wissen ob er läuft bzw. das Shield angesteuert ist.
Ohne extra HW wäre nur der Weg dann einen Merker mit zu schleppen.
BG
4711:
So schwer zu schleppen hat man an einem Merker aber auch nicht gerade
uwefed
March 10, 2021, 8:14am
#7
Wenn Du das orginal Arduino Motor Shield nimmst dann kannst Du da den Motorstrom abgreifen.
grüße Uwe
4711:
Das ist ja der Waaaahnsinn
system
closed
July 8, 2021, 12:32pm
#9
