Motor Shield and Attachinterrupt, little interference problem
please spent some time to get proper layout - CTRL-T does help you
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x0E, 0xCE, 0xA1 }; //physical mac address
byte ip[] = {
  192, 168, 0, 2 }; // ip in lan
byte gateway[] = {
  192, 168, 0, 1 }; // internet access via router
byte subnet[] = {
  255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
int switchhh = 2;
int pwm = 5;
int dir = 7;
int valswitch = 0;
  //Setup Channel A from Motor shield
  pinMode(pwm, OUTPUT); //Initiates Motor Channel A pin
  pinMode(dir, OUTPUT); //Initiates Brake Channel A pin
  //Start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
  attachInterrupt(1, motor_stop, RISING);
  // Create a client connection
  if (client)
    while (client.connected())
      if (client.available())
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100)
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n')
          Serial.println(readString); //print to serial monitor for debuging
            client.println("HTTP/1.1 200 OK"); //send new page
          client.println("");
          client.println("<HTML><HEAD><TITLE>Projet d'&eacute;tude : ARDUINO et Contr&ocirc;le de panneau solaire</TITLE></HEAD>");
          client.println("<BODY>");
          client.println("<H3>Projet d'&eacute;tude : ARDUINO et Contr&ocircle de panneau solaire</H3>");
          // DIY buttons
          client.println("<a href=/?up2 >Monter</a> <a href=/?down3 >Descendre</a> <a href=/?stop4 >STOP</a>");
          client.println("</BODY></HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf('2') > 0)//checks for 2 MONTER
            Serial.println("Bouton monter appuyer !!");
            digitalWrite(dir, HIGH);
            analogWrite(pwm, 255);
            delay(3000);
            m_stop();
            Serial.println("Bouton monter appuyer !!  FIN BOUCLE");
          if(readString.indexOf('3') > 0)//checks for 3 DESCENDRE
            Serial.println("Bouton descendre appuyer !!");
            digitalWrite(dir, LOW);
          if(readString.indexOf('4') > 0)//checks for 3 STOP
            Serial.println("Bouton STOP appuyer !!");
            m_stop();
            Serial.println("Bouton STOP appuyer !!  FIN BOUCLE");
          valswitch = digitalRead(switchhh);
          if (valswitch == HIGH)
            //clearing string for next read
            readString="";
void motor_stop()
  Serial.println("motor_stop begin");
  m_stop();
  Serial.println("motor_stop end");
void m_stop()
  Serial.println("m_stop start");
  digitalWrite(pwm, 0);
  Serial.println("m_stop end");
and please use only comments when in sync with the code >>> if(readString.indexOf('4') > 0)//checks for 3 STOP
quick code review shows no direct errors. Are you running out of RAM?
