Motor shield and maxsonar sensor help
Hi
I have a ladyada motor shield, a maxsonar sensor and an old remote control car. I am trying to make the car stay a set distance from away from me, so that as I walk/run towards it it moves away in a straight line. However I can’t seem to get it to work.
The code so far:
#include <AFMotor.h>
const int anPin = 7;     //Maxsonar on Analogue pin 7\
//variables needed to store values
long anVolt, inches, cm;
int sum=0;          //Create sum variable so it can be averaged
int avgrange=1;     //Quantity of values to average (sample size)
int minDist = 30;        //Distance at which motor goes at full speed.
int optimumDist = 100;    //How far  away you want the car/thing
int mapResult = 0;   //Variable to store the mapping result
int motorSpeed = 0;  //Variable for motor speed
AF_DCMotor motor(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
  Serial.begin(9600);           // set up Serial library at 9600 bps
  motor.setSpeed(motorSpeed);     // Set motor to motorSpeed Value
///////////////////////// Ping/MaxSonar stuff ///////////////////////////////////
  pinMode(anPin, INPUT);
  for(int i = 0; i < avgrange ; i++)
    //Used to read in the analog voltage output that is being sent by the MaxSonar device.
    //Scale factor is (Vcc/512) per inch. A 5V supply yields ~9.8mV/in
    anVolt = analogRead(anPin);
    sum += anVolt;
    delay(50);
  inches = sum/avgrange;
  cm = inches * 2.54;
  Serial.print(cm);
  Serial.print("cm   --  Maxsonar Reading");
  //reset sample total
  sum = 0;
 //////////////////////////// Mappin////////////////////////////////
mapResult = map(cm, minDist, optimumDist, 0, 255);
if (cm < minDist)
  motorSpeed = 255;
else if (cm < optimumDist)
  motorSpeed = 255 - mapResult;
else if (cm > optimumDist)
motorSpeed = 0;
Serial.print(mapResult);
Serial.print("   mapResult");
    Serial.print(motorSpeed, DEC);
    Serial.print("  Motorspeed output");
      //////// Turn the Motor ///////////////////
  motor.run(FORWARD);      // turn it on going forward
Serial Monitor shows that the motor speed variable is changing accordingly, however the motor doesn’t actually move at all. The shield and motor work fine when I use small example test programs. I’m sure it’s something very simple but even with a good search of the forums I can’t work it out. Any help really appreciated!
if (cm < minDist)
   motorSpeed = 255;
   motorSpeed = 0;
Shouldn’t the tests be based on mapResult, rather than cm?
Also, shouldn’t there be a call to motor.setSpeed in loop, rather than in setup()?
I know that the pinMode statement in loop should be in setup, instead?
hello im working on something like that. did you ever get it to work.??
