Hi everybody! This is my first arduino project.
I'm trying to hack an rc car supplied by a 7.2 V, 1800 mAh, i want to replace the motor controller with an arduino UNO and a Motor Shield DK Electronics, buyed on AliExpress..
I've wired the EXT_PWR with a row of 5 AA IKEA Bateries, 1.5 volt, 1500 mAh each, removed the jumper between Arduino and the Shield, suppling Arduino via USB connection.
I've downloaded the adafruit motorshield library v.1, followed all steps to install it, wired the motor to motor port 4 and uploaded the motor Test default Sketch.
Motor doesn't move but i can hear a whistle coming from it.
Testing on a multimeter i see that the shield supplies from 0 to 1.4 A
Also wiring a simple LED it brights but has a dim light.
This happens for each DC motor port, and also with an other smaller motor.
Note: the motor supplied directly from the battery works fine!
It seems that arduino / the shield give to the motor too little energy..
I don't understand what's wrong, have you any idea?
Thanks ![]()
dew
