Motor shield problem
Hi, i am trying to turn 2 motors on and off using a IR remote control and the R-robotics 2A motor shield, i can turn 1 motor on and off or 2 at the same time but if i try to give each motor its own on off buttons only 1 motor works even though the serial monitor is saying the buttons been pressed.I must be missing something or got the code wrong i would be grateful of any help.
// IR 2 motor test
#include <IRremote.h> // use the library
int E1 = 6;
int M1 = 7;
int E2 = 5;
int M2 = 4;
int receiver = 11; // pin 1 of IR receiver to Arduino digital pin 11
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results;
pinMode(M1, OUTPUT);
pinMode(M2, OUTPUT);
  Serial.begin(9600); // for serial monitor output
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) // have we received an IR signal?
      if (results.value == 0x687CBE2L) {   // 0x687CBE2L button press on remote control
      Serial.write("1st motor ON\n");
digitalWrite(M1,HIGH);
analogWrite(E1, 200); //PWM Speed Control
    delay(100);                       // waits 1s for the motor to reach the speed
    else if (results.value == 0x687CBEAL) {  //Press off button on remote control
      Serial.write("1st motor off\n");
analogWrite(E1, 0); //PWM Speed Control
          if (results.value == 0x687CBD0) {   // On button press on remote control
      Serial.write("2nd motor ON\n");
digitalWrite(M2,HIGH);
analogWrite(E2, 200); //PWM Speed Control
    else if (results.value == 0x687CBD6) {  //Press off button on remote control
      Serial.write("2nd motor off\n");
analogWrite(E2, 0); //PWM Speed Control
    Serial.println(results.value, HEX); // display it on serial monitor in hexadecimal
    irrecv.resume(); // receive the next value
  }  // Your loop can do other things while waiting for an IR command
Schematic?
Solved
This section:
Does not follow your else if model used elsewhere. You only test for 0x687CBD0 inside the if which established that results.value is in fact 0x687CBEAL.
This:
Should be
        else if (results.value == 0x687CBD0)
and you'll then have to sort out the braces to get it to compile
Edit: Too slow!
