Motor shield programing for 6 servos
I am trying to control 6 servo for a dust collection. I can get the following code to work, but when I try to add 5 and 6 it locks up. and the way I am trying to use all 6 commented out.
This script was created by Bob Clagett for I Like To Make Stuff
For more projects, check out iliketomakestuff.com
Includes Modified version of "Measuring AC Current Using ACS712"
Parts of this sketch were taken from the keypad and servo sample sketches that comes with the keypad and servo libraries.
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm  =  Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
// our servo # counter
uint8_t servoCount =5;
uint8_t servonum = 0;
const int OPEN_ALL = 100;
const int CLOSE_ALL = 99;
boolean buttonTriggered = 0;
boolean powerDetected = 0;
boolean collectorIsOn = 0;
int DC_spindown = 3000;
const int NUMBER_OF_TOOLS = 5;    //6;
const int NUMBER_OF_GATES = 5;    //6;
String tools[NUMBER_OF_TOOLS] = {"Sander","Table Saw","Miter Saw","Band Saw"}; //,"Floor Sweep","Planner"
int voltSensor[NUMBER_OF_TOOLS] = {A0,A1,A2,A3};   //{A0,A1,A2,A3,A4,A5}
long int voltBaseline[NUMBER_OF_TOOLS] = {0,0,0,0};  //{0,0,0,0,0,0}
//DC right, Y, miter, bandsaw, saw Y, tablesaw, floor sweep
//Set the throw of each gate separately, if needed
int gateMinMax[NUMBER_OF_GATES][2] = {
  /*open, close*/
  {270,400},  //Table Saw
  {270,400},  //Miter Saw
  {270,400},  //Band Saw
  {270,400},  //Sander
  //{200,405},  //Planner
  //{200,405},  //Floor Sweep
//keep track of gates to be toggled ON/OFF for each tool
int gates[NUMBER_OF_TOOLS][NUMBER_OF_GATES] = {
  {1,0,0,0},
  {0,1,0,0},
  {0,0,1,0},
  {0,0,0,1},
  //{0,0,0,0,1},
  //{0,0,0,0,0,1,},
const int dustCollectionRelayPin = 11;
const int manualSwitchPin = 12; //for button activated gate, currently NOT implemented
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
double ampThreshold = .20;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//button debouncing
int state = HIGH;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
void setup(){
  pinMode(dustCollectionRelayPin,OUTPUT);
  pwm.begin();
  pwm.setPWMFreq(60);  // Default is 1000mS
 //record baseline sensor settings
 //currently unused, but could be used for voltage comparison if need be.
  for(int i=0;i<NUMBER_OF_TOOLS;i++){
    pinMode(voltSensor[i],INPUT);
    voltBaseline[i] = analogRead(voltSensor[i]);
void loop(){
  // use later for button debouncing
  reading = digitalRead(manualSwitchPin);
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    if (state == HIGH){
      state = LOW;
     buttonTriggered = false;
    } else{
      state = HIGH;
     buttonTriggered = true;
    time = millis();
  previous = reading;
   Serial.println("----------");
   //loop through tools and check
   int activeTool = 50;// a number that will never happen
      if( checkForAmperageChange(i)){
        activeTool = i;
        exit;
      if( i!=0){
        if(checkForAmperageChange(0)){
          activeTool = 0;
          exit;
  if(activeTool != 50){
    // use activeTool for gate processing
    if(collectorIsOn == false){
      //manage all gate positions
      for(int s=0;s<NUMBER_OF_GATES;s++){
        int pos = gates[activeTool][s];
        if(pos == 1){
          openGate(s);
          closeGate(s);
      turnOnDustCollection();
  } else{
    if(collectorIsOn == true){
        delay(DC_spindown);
      turnOffDustCollection();
boolean checkForAmperageChange(int which){
   Voltage = getVPP(voltSensor[which]);
   VRMS = (Voltage/2.0) *0.707;
   AmpsRMS = (VRMS * 1000)/mVperAmp;
   Serial.print(tools[which]+": ");
   Serial.print(AmpsRMS);
   Serial.println(" Amps RMS");
   if(AmpsRMS>ampThreshold){
    return true;
   }else{
    return false;
void turnOnDustCollection(){
  Serial.println("turnOnDustCollection");
  digitalWrite(dustCollectionRelayPin,1);
  collectorIsOn = true;
void turnOffDustCollection(){
  Serial.println("turnOffDustCollection");
  digitalWrite(dustCollectionRelayPin,0);
  collectorIsOn = false;
float getVPP(int sensor)
  float result;
  int readValue;             //value read from the sensor
  int maxValue = 0;          // store max value here
  int minValue = 1024;          // store min value here
   uint32_t start_time = millis();
   while((millis()-start_time) < 500) //sample for 1 Sec
       readValue = analogRead(sensor);
       // see if you have a new maxValue
       if (readValue > maxValue)
           /*record the maximum sensor value*/
           maxValue = readValue;
       if (readValue < minValue)
           minValue = readValue;
   // Subtract min from max
   result = ((maxValue - minValue) * 5.0)/1024.0;
   return result;
void closeGate(uint8_t num){
  Serial.print("closeGate ");
  Serial.println(num);
  pwm.setPWM(num, 0, gateMinMax[num][1]);
void openGate(uint8_t num){
  Serial.print("openGate ");
    delay(100);
    pwm.setPWM(num, 0, gateMinMax[num][0]-5);
any help would really help with what I am doing wrong
What does your serial output tell you?
What's the "50" in there?
it hangs on close gate 0
This code was taken for I loke to make stuff on you tube and is free to use not sure what it is used for
taken from I like
Can you post the version of the code that fails?
 * This code is for the project at
 * http://www.iliketomakestuff.com/how-to-automate-a-dust-collection-system-arduino
 * All of the components are list on the url above.
https://web.archive.org/web/20190928042820/http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/acs712-arduino-ac-current-tutorial/
Uses https://github.com/adafruit/Adafruit-PWM-Servo-Driver-Library
#include <Wire.h>
// have!
uint8_t servoCount =6;
const int NUMBER_OF_TOOLS = 6;    //6;
const int NUMBER_OF_GATES = 6;    //6;
String tools[NUMBER_OF_TOOLS] = {"Sander","Table Saw","Miter Saw","Band Saw","Floor Sweep","Planner"}; //,"Floor Sweep","Planner"
int voltSensor[NUMBER_OF_TOOLS] = {A0,A1,A2,A3,A4,A5};    //{A0,A1,A2,A3};   //{A0,A1,A2,A3,A4,A5}
long int voltBaseline[NUMBER_OF_TOOLS] = {0,0,0,0,0,0};
  /*open, close*/
  {270,400},  //Sander
  {1,0,0,0,0,0},
  {0,1,0,0,0,0},
  {0,0,1,0,0,0},
  {0,0,0,1,0,0},
  {0,0,0,0,1,0},
  {0,0,0,0,0,1},
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//button debouncing
void setup(){
  pwm.begin();
void loop(){
    if (state == HIGH){
      state = LOW;
    } else{
      state = HIGH;
    time = millis();
  previous = reading;
        activeTool = i;
        exit;
      if( i!=0){
          activeTool = 0;
          exit;
        if(pos == 1){
          openGate(s);
          closeGate(s);
  } else{
        delay(DC_spindown);
    return true;
   }else{
    return false;
  float result;
   return result;
    delay(100);
It has something to do with D4 and D5 analog input. the four will work if I remove pin
4 and 5
Can you explain what you mean there, please?
'D' usually means "Digital"
D4 and D5 of the analog in pinof the Arduino
are A5 and A4 not occupied by I2C?
the pins that are on the shield but connect to the same I thought.
I am sorry this is my first time working with a arduino
I have all connected to the shield It looked like the go through to the arduino
If you've only got six servos, why use a shield?
What's wrong with the Servo library?
(Can you see that D4 and D5 are not the same as A4 and A5?)
I have motor 1 connected to A0 motor 2 to A1 motor 3 to A2 motor 4 to A3 motor 5 to A4 motor 6 to A5 sorry I said D should have been A
A4 and A5 are used for I2C, which is what the shield uses. You can't also use them to detect current from tools running.
how would I hook them up to make motor 4 and 5 current to work
Like I said I have never work with a arduino and just assumed the patteren...I know what assume does...lol
As Awol said. Forget the Adafruit shield and use the servo library directly. Your code will need surgery though. If you don't fancy that, you could get something like a Mega, which has more analog pins available.
ATtiny13A has analog input and can convert each Current sensor module output from analog to digital.
