Hi
As the title says I am trying to stack a motor shield r3 and a sparkfun xbee shield SparkFun XBee Shield - WRL-12847 - SparkFun Electronics on top of a mega 2560 r3. But it is not working. I am trying to run the following sketch.
If I remove the xbee shield then my motors run the way they should but if I leave the xbee shield on the motors simply dont turn.
This same setup is working with a DFrduino motor shield.
Can someone help me with this.
#include "Arduino.h"
#include <QuadratureEncoder.h>
// Left Motor Encoder uses external interupts 2 and 3 on pins 20 and 21
QuadratureEncoder encoderMotorL(21,20); //for all others
// Right Motor Encoder uses external interupts 5 and 4 on pins 18 and 19
QuadratureEncoder encoderMotorR(18, 19);
int PwmMotorL = 3, PwmMotorR = 11;
int DirMotorL = 12, DirMotorR = 13;
long encL =0, encR =0;
//Initialize Serial Link
Serial2.begin(9600);
//Set Initial Encoder Positions
encoderMotorL.setPosition(0);
encoderMotorR.setPosition(0);
//Assign Interrupts for Encoder A and B
attachInterrupt(3, HandleMotorLInterruptA, CHANGE); // Pin 20
attachInterrupt(2, HandleMotorLInterruptB, CHANGE); //Pin 21
attachInterrupt(5, HandleMotorRInterruptA, CHANGE); // Pin 18
attachInterrupt(4, HandleMotorRInterruptB, CHANGE); // Pin 19
//Initialize motor spin direction
digitalWrite(DirMotorL, LOW); digitalWrite(DirMotorR, LOW);
analogWrite(PwmMotorL,255); analogWrite(PwmMotorR,255);
Serial2.print("Running \n");
encL = encoderMotorL.getPosition();encR = encoderMotorR.getPosition();
Serial2.print("\n");
Serial2.print(encL);Serial2.print("\t");Serial2.print(encR);
delay(5000);
// Interrupt service routines for motor 1 quadrature encoder
void HandleMotorLInterruptA()
{ encoderMotorL.OnAChanged(); }
void HandleMotorLInterruptB()
{ encoderMotorL.OnBChanged(); }
// Interrupt service routines for motor 2 quadrature encoder
void HandleMotorRInterruptA()
{ encoderMotorR.OnAChanged(); }
void HandleMotorRInterruptB()
{ encoderMotorR.OnBChanged(); }
Thank you for your help
--ksp
