Hey ,
here's the story:
I'm currently trying to build a small independent rover from my old lego technics. Crucially I power two 9v DC motors (2838) using an arduino motor shield R3 (http://arduino.cc/en/Main/ArduinoMotorShieldR3) in combination with an arduino uno.
I connect the motors independently to the two outputs of the motor shield and use an external 9V power supply to the arduino plug-in jack which also powers the board.
All this worked fine in the beginning with both motors doing their job at full speed. (The software should be OK, I did set all needed pins on their desired values (brakes off, directions on, pwm to 255)).
Now here's the problem:
After having tinkered around a bit with my design it seems to me as if I had broken the motor shield. As I said the software worked in the beginning. I also double checked the motors by directly connecting a 9V battery to them, they both work just fine. Also the arduino board itself is unharmed, I checked it with other designs just to make sure.
But the motor shield does not supply enough power to the outputs anymore and so the motors don't run properly. I used my multimeter on the motor shield's output terminal screws and current was down to about 7,4 V. Is this a normal behavior or is the shield really broken ? If so, what could be a possible cause for the lack of power on the output?
I would be very thankful for any comments or hints, since googling the problem did not show any useful results.
Best,
Jannis
