motor shield r3 output in series
dear all,
i'm using the arduino motor shield r3 in order to controll a 24v DC motor (http://en.manu-systems.com/EMG49.shtml) as I can understand from the motor shield datasheet (http://arduino.cc/en/Main/ArduinoMotorShieldR3) is not allowed to control more than 18V motor.
Is it possible to connect in series the 2 output of the shield (12v+12v) to obtain 24v?
thank you
alessandro
No because both shields need a common ground for the logic signals.
Even if that were true it would be problematical to say the least since these are H-bridges and output polarity reverses - separate floating power supplies into the shields would be needed - all seems like a can of worms.
The absolute maximum is quoted as 18V for one of the shields: a different shield/controller is going to be the answer for 24V operation.
thank you MarkT,
I see, i found this shield in the forum (http://www.robotshop.com/eu/arduino-compatible-mega-motor-shield-1a-5-28v-2.html). this seams to be the solution.
thank you again
alessandro
