Hi,. ...
i can't fined the program of Motor Shield R3 in arduino-1.0.6 ???
i want him to move the libraries pleas i want help ?
Hi,. ...
Have you seen this:-
You do not need a library to drive this, you just put the appropriate pins high or low.
Grumpy_Mike:
http://arduino.cc/en/Main/ArduinoMotorShieldR3You do not need a library to drive this, you just put the appropriate pins high or low.
i with u .... but this error i don't know why show ???
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
sketch_nov12a:9: error: 'MotorShieldR3' does not name a type
sketch_nov12a.ino: In function 'void loop()':
sketch_nov12a:35: error: 'yellowCar' was not declared in this scope
sketch_nov12a:103: error: 'yellowCar' was not declared in this scope
No, no one can know until you post your code.
and this is program
New Text Document.txt (3.24 KB)
No you do not post code like that, it comes out looking like this:-
†Serial.begin(9600); †//Set the baud rate to that of your Bluetooth module.
†pinMode(pinfrontLights , OUTPUT);
†pinMode(pinbackLights , OUTPUT);
void loop(){
†if(Serial.available() > 0){
† †timer1 = millis(); †
† †prevCommand = command;
† †command = Serial.read();
† †//Change pin mode only if new command is different from previous. †
† †if(command!=prevCommand){
† † †//Serial.println(command);
† † †switch(command){
† † †case 'F': †
That will never compile.
Take you .pde file and zip it up and then attache it.
Grumpy_Mike:
No you do not post code like that, it comes out looking like this:-void setup()
void loop(){
† † †case 'F': †
That will never compile. Take you .pde file and zip it up and then attache it.
this i write before the program
Sorry no idea what that means.
Just use the pins to control the motor. Here is an example of initialising the motor's pins.
// these are the pins connected to the Arduino Motor Shield:
const int pwmA = 3;
const int brakeA = 9;
const int dirA = 12;
const int pwmB = 11;
const int brakeB = 8;
const int dirB = 13;
Initialize the stepper library using the direction pins (dirA and dirB)
to control the motor shield.
void setup () {
// set up all of the pins of the motor shield as outputs:
pinMode(brakeA, OUTPUT);
pinMode(dirA, OUTPUT);
pinMode(brakeB, OUTPUT);
pinMode(dirB, OUTPUT);
// set the brake pins LOW to turn them off:
digitalWrite(brakeA, LOW);
digitalWrite(brakeB, LOW);
When you want the motor to move, remove the break and do an analogWrite to the pwm pin for the motor.
Hi everyone.
I have a problem with the arduino motor shield rev3.
I connected it to an Arduino UNO without stacking it, I use cables from the outputs. I did this because I need to control 6 motors and I have 3 arduino motor shields, if I stack all of them they will not work.
I am using 9v batteries, one to power on the UNO and another for the motor shield.
The problem I have is that motor shield output A is running slower than output B, but it only happens in the forward direction, in backward direction both outputs speeds is the same.
Any suggestion?
Thanks
Any suggestion?
Start your own thread.
