Motor shield reversed with joystick
UNO R3, Arduino motor shield R3, dc brushed motor, analog joystick.
Joystick to left (532-1023) motor moves as expected, joystick right (492-0), motor reverses as expected but duty cycle is reversed (motor starts full speed, reduces as stick moved right).
Any help will be greatly appreciated
Dennis
 * This is an attempt to control a Motor Shield with a joystick
 * Processor board is an Arduino UNO v3
 * Shield is an Arduino Motor Shield r3
int analogInPin = A0;
int directionPin = 12; //asign direction pin
int brakePin = 9;  //asign brake pin
int pwmPin = 3;  //asign pwm pin
int joystickValuex = 0; //center of pot x axis
//int joystickValuey = 127.5; //center of pot y axis
int outputValue = 0; //start with "0" output
  //define pins
  pinMode(directionPin, OUTPUT);
  pinMode(pwmPin, OUTPUT);
  pinMode(brakePin, OUTPUT);
  joystickValuex = analogRead(analogInPin) / 1;
  outputValue = map(joystickValuex, 0, 4096, 0, 100);
  analogWrite(pwmPin, joystickValuex) ;
  //scale value to between 0 and 180
  //joystickValuex = map(joystickValuex, 0, 1000, 0, 200);
  if (joystickValuex >= 4)
    //example
    digitalWrite(brakePin, LOW);
    digitalWrite(directionPin, HIGH);
    analogWrite(pwmPin, joystickValuex);
    delay(10);
  { digitalWrite(brakePin, LOW);
    //Serial.print(directionPin);
  delay(30);
  // print out the value you read:
  Serial.println(joystickValuex);
  // Serial.println(joystickValuey);
An analogRead() gives you an integer between 0 and 1023. An analogWrite() requires an integer between 0 and 255 for the PWM value.
My best guess:
const int analogInPin = A0;
const int directionPin = 12; //asign direction pin
const int brakePin = 9;  //asign brake pin
const int pwmPin = 3;  //asign pwm pin
  //define pins
  int joystickValuex = analogRead(analogInPin);
  if (joystickValuex < 493)
    digitalWrite(directionPin, HIGH); // Right
    analogWrite(pwmPin, map(joystickValuex, 492, 0, 0, 255));
    else if (joystickValuex > 531)
    digitalWrite(directionPin, LOW); // Left
    analogWrite(pwmPin, map(joystickValuex, 532, 1023, 0, 255));
    // Dead zone
    digitalWrite(pwmPin, 0); // Stop
    digitalWrite(brakePin, HIGH);  // Apply brake
  delay(30);
@johnwasser
This worked after i re assigned A0 to A2. On the motor shield A0 & A1 are used for current sensing, if used as potpins the results are seemingly unpredictable.
Thank you for pointing out the else if statement where i was just using multiple if's.
Any pointers on your re write are welcome. Im here to learn the language. Long time RS274 (CNC g-code) programmer here, so some of it makes sense... im learning.
@ToddL1962
I appreciate youre input, im not sure how it ties in here, im a total rookie.
If you could tie it in, I'd appreciate it, as I'm here to learn.
Thanks in advance.
I would also like to add another analog input, I'm still trying (for no good reason) to not use a .h file.
If anyone can point me in the right direction...
Thanks
Like a Y axis? What do you want it to do?
I'd like it to control the second axis the same exact way the first (X axis) on the motor shield is controlled.
I'm starting to read the array section. I'm assuming that's what I need?
With just two, arrays might be overkill. I usually recommend arrays if you have three or more of the same object all doing roughly the same thing. For two, it's easy enough to come up with names for the variables.
So would i add additional "if" or "els if" blocks for the y axis?
I added definitions for y, but think i need some additional action.
Yes. Do the same as for X. Get the value from the analog input pin and use 'if' and 'else if' to decide what the various ranges of value do.
It works in two axis, or both motor channels in dc brushed motor configuration.
So basically, i can use "else if" as many times as needed?
You're great for helping out. Thank you.
Here's the code.
`/**** This is an attempt to control a Motor Shield with a joystick Processor board is an Arduino UNO v3 Shield is an Arduino Motor Shield r3 */
const int analogInPin0 = A2;
const int directionPin0 = 12; //asign direction pin
const int brakePin0 = 9; //asign brake pin
const int pwmPin0 = 3; //asign pwm pin
const int analogInPin1 = A3;
const int directionPin1 = 13; //asign direction pin
const int brakePin1 = 8; //asign brake pin
const int pwmPin1 = 11; //asign pwm pin
  Serial.begin(9600); //define pins
  pinMode(directionPin0, OUTPUT);
  pinMode(pwmPin0, OUTPUT);
  pinMode(brakePin0, OUTPUT);
  pinMode(directionPin1, OUTPUT);
  pinMode(pwmPin1, OUTPUT);
  pinMode(brakePin1, OUTPUT);
} void loop()
  int joystickValuex = analogRead(analogInPin0) ;
  int joystickValueY = analogRead(analogInPin1) ;
    digitalWrite(brakePin0, LOW);
    digitalWrite(directionPin0, LOW); // Right
    analogWrite(pwmPin0, map(joystickValuex, 492, 0, 0, 140));
    Serial.println ("X RIGHT");
    else if (joystickValueY < 493)
      digitalWrite(brakePin1, LOW);
      digitalWrite(directionPin1, LOW); // Right
      analogWrite(pwmPin1, map(joystickValueY, 492, 0, 0, 140));
      Serial.println ("Y DOWN");
      digitalWrite(directionPin0, HIGH); // Left
      analogWrite(pwmPin0, map(joystickValuex, 532, 1023, 0, 140));
      Serial.println ("X LEFT");
    else if (joystickValueY > 531)
      digitalWrite(directionPin1, HIGH); // Left
      analogWrite(pwmPin1, map(joystickValueY, 532, 1023, 0, 140));
      Serial.println ("Y UP");
    else   { // Dead zone
      digitalWrite(pwmPin0, 0); // Stop
      digitalWrite(brakePin0, HIGH); // Apply brake
      digitalWrite(pwmPin1, 0); // Stop
      digitalWrite(brakePin1, HIGH); // Apply brake
    delay(10); // allow brae to act before reversing
    Serial.println(joystickValuex); //print out the value
