Everything works on the sketch until I use the potentiometer - would someone please take a look and advise me - I am currently only using MotorA
Many thanks in advance.
typ/*************************************************************
Version 1.0 Sept 2021
Courtesy of:
https://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/
Buttons - LC_baseTools
Function Channel A Channel B
Direction Digital 12 Digital 13 //do not change motor shield
Speed (PWM) Digital 3 Digital 11 //do not change motor shield
Brake Digital 9 Digital 8 //do not change motor shield
Current Sensing Analog 0 Analog 1 //do not change motor shield
LED Digital 2 Digital 3 // brake led
Toggle Digital 4 Digital 5 //forward/reverse (ON - OFF)
Button Digital 6 Digital 7 //brake
// Buttons - LC_baseTools
#include <mechButton.h>
// motor A
mechButton button1(4); // forward/reverse
mechButton button3(6); // brake
const int analogInPin1 = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin1 =A2; // Analog output pin
int sensorValue1 = 0; // value read from the pot
int outputValue1 = 0; // value output to the PWM (analog out)
//Setup Channel A
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
// pot
pinMode(A0, INPUT); //Motor A
pinMode(A1, INPUT); //Motor B
//Led
pinMode(2, OUTPUT);
while (!Serial) { };
idle();// this give us multitasking - LC_baseTools
if (button3.trueFalse()) //can we move
do_BrakeON();// no brake is true
do_BrakeOFF();// yes brake is false - we can move
if (button1.trueFalse())// which way can we move
do_Reverse(); // reverse
do_Forward(); // forward
void read_Pot()
Serial.print("Reading the pot "); Serial.println();
// read the analog in value:
sensorValue1 = analogRead(analogInPin1);
// map it to the range of the analog out:
outputValue1 = map(sensorValue1, 0, 1023, 0, 255);
// stop any buzzing
if (outputValue1 < 8 )outputValue1 = 0;
if (outputValue1 > 8 )outputValue1 = 0;
// change the analog out value:
analogWrite(analogOutPin1, outputValue1);///////this does not seem to work
// wait 2 milliseconds before the next loop for the analog-to-digital
// converter to settle after the last reading:
delay(2);
void do_Forward()
Serial.print("Forward "); Serial.println();
read_Pot();
digitalWrite(9, HIGH); //Engage the Brake for Channel A
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
// analogWrite(3, 255); //Spins the motor on Channel A at full speed - THIS WORKS
void do_Reverse()
Serial.print("Reverse "); Serial.println();
read_Pot();
digitalWrite(12, LOW); //Establishes backward direction of Channel A
// analogWrite(3, 255); //Spins the motor on Channel A at half speed- THIS WORKS
void do_BrakeON()
Serial.print("brake ON "); Serial.println();
digitalWrite(2, 0); //Turn on the light -
void do_BrakeOFF()
Serial.print("brake OFF "); Serial.println();
digitalWrite(2, 1); //Turn OFF the light -
digitalWrite(9, LOW); //Release the Brake for Channel A
//----------------------------------------------------------------------------e or paste code here
I recommend you change the names from 'button1' and 'button3' to DirectionAButton and BrakeAButton.
A2 is not an analog (PWM?) output pin.
DO NOT USE pinMode() ON PINS YOU ONLY USE FOR analogRead().
This is equivalent to outputValue1 = sensorValue1 / 4;
Give Pin 3 and Pin 12 meaningful names so you don't have to explain in a comment what you are doing. Note: Engaging the brakes for a few microseconds is not going to do much.
I have made most of the suggested changes and added an array to handle motor A and B.
In the process I have managed to get myself in a pickle - perhaps you could assist me a little with the logic in the callback()
Also I think I am reading the potentiometer too many times and am not too sure where or how to make the change for this.
Throttle's for two blocks on a model railway
Motor shield Deek-robot
UNO R3
Version 3.0 Sept 2021- this works for two lines from the motor
Courtesy of:
And all the Elves at Arduino
msDirection Digital 12 Digital 13 //do not change motor shield
msSpeed Digital 3 Digital 11 //do not change motor shield
msBrake Digital 9 Digital 8 //do not change motor shield
msSensing Analog 14 Analog 15 //do not change motor shield
ledBrake Digital 2 Digital 10 //brake led
toggleDirection Digital 4 Digital 5 //forward/reverse
buttonBrake Digital 6 Digital 7 //brake
#include <idlers.h>
const int msDirection[] {12, 13}; // do not change motor
const int msSpeed[] {3, 11}; // do not change motor
const int msBrake[] {9, 8}; // do not change motor
const int msSensing[] {14, 15}; // analog A0 and A1
const int ledBrake[] {2, 10}; // led indicates brake on/off
const int pinCount = 2; // number of tracks
mechButton buttonBrake[] {6, 7}; // pushbutton
mechButton toggleDirection[] {4, 5}; // toggle switch
//Setup Channel A and B
for (int x = 0; x < pinCount; x++)
pinMode(msDirection[x], OUTPUT);
pinMode(msSpeed[x], OUTPUT);
pinMode(msBrake[x], OUTPUT);
pinMode(msSensing[x], OUTPUT);
pinMode(ledBrake[x], OUTPUT);
buttonBrake[x].setCallback(myCallback); // Set up our callback.
toggleDirection[x].setCallback(myCallback);
* This is set for motor A for testig only
* if the brake is ON the direction cannot be moved
* if the brake is OFF the direction can be moved
void myCallback(void)
bool brakeStatus[pinCount];
int x = 0;
Serial.print("Brake A just became ");
if (buttonBrake[x].trueFalse() )
Serial.println("ON");
do_BrakeON(x);
brakeStatus[x] == true;
Serial.println("OFF");
do_BrakeOFF(x);
brakeStatus[x] == false;
// this is not working correctly - it should only
// work when the brake is false.
Serial.print("Direction A just became ");
if (toggleDirection[x].trueFalse() && brakeStatus[x]== false)
Serial.println("forward");
do_Forward(x);
Serial.println("reverse");
do_Reverse(x);
void read_Pot(int i)
{ Serial.print("read pot "); Serial.println();
int sensorValue = analogRead(msSpeed[i]);
int outputValue = sensorValue / 4;
analogWrite(msSensing[i], outputValue);
void do_Forward(int i)
read_Pot(i);
digitalWrite(msBrake[i], HIGH); sleep(500);
digitalWrite(msDirection[i], HIGH);
digitalWrite(msBrake[i], LOW);
void do_Reverse(int i)
read_Pot(i);
digitalWrite(msDirection[i], LOW);
void do_BrakeON(int i)
digitalWrite(ledBrake[i], 0);
void do_BrakeOFF(int i)
digitalWrite(ledBrake[i], 1);
digitalWrite( msBrake[i], LOW);
//-----------------------------end--------------------------------------------
ype or paste code here
