motor stop after 3 seconds
I’ve tried this code to make one project but the motor keeps on spinning without stopping after 3 seconds. Can anyone help? Thanks in advance!
sketch_jun02a.ino (1.86 KB)
Please include short programs in your Post like this
#define echoPin 7 // Echo Pin
#define trigPin 8 // Trigger Pin
#define LEDPin 13 // Onboard LED
#define motorPin 3
int motorState = 0;             // motorState used to set the LED
unsigned long previousMillis;        // will store last time LED was updated
unsigned long startTime;
long interval = 1000;
boolean lastTrip;
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
int triggerDistance = 10;
//long duration, distance; // Duration used to calculate distance
  pinMode(motorPin, OUTPUT);
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(LEDPin, OUTPUT); // Use LED indicator (if required)
  long distance = getDistance();
  if (distance > maximumRange)
    Serial.println(F("Too Far!!"));
    digitalWrite(LEDPin, HIGH);
  if (distance < minimumRange)
    Serial.println(F("Too Close!!"));
    digitalWrite(LEDPin, LOW);
  boolean tripped = (distance <= triggerDistance ? 1 : 0); // flag if triggered
  if (tripped)
    if (tripped != lastTrip)
      startTime = millis();
      motorState = 1;
  lastTrip = tripped;
  if (motorState == 1)
    runMotor();
long getDistance()
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(echoPin, HIGH);
  long dist = duration/58.2;
  return dist;
void runMotor()
  if( millis() - startTime < 3000UL) // Three Second Interval
    analogWrite(motorPin, 25);
    //or digitalWrite(motorPin, HIGH);
    analogWrite(motorPin, 0);
    //or digitalWrite(motorPin, LOW);
    motorState = 0;
You need to add some Serial.print() statements so you can see if the value of startTime is being set correctly.
…R
@jeevanreddy312
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
