Hi Steve, thankyou so much for all of your help
I've attached a diagram to check that i've understood right, will that method keep the servo running for 6+ hours? should I plug it in to a usb plug too or will that not make a difference?
I've also attached a photo of the kit that i bought i was wondering if anything included in that would be a better method/could do the job to save me from buying anything extra
it was suggested that this might work what do you think https://www.amazon.co.uk/JX2-Converter-Compatible-External-Included/dp/B07Q9ZCBGH/ref=sr_1_fkmr0_1?keywords=SATA%2FPATA%2FIDE+to+USB+2.0+Adapter+Converter+Cable+for+2.5+%2F+3.5+Inch+Hard+Drive+B&qid=1558200960&s=gateway&sr=8-1-fkmr0 ?
sorry for asking so many questions, thanks again
-Arianne
(here is a list of what is in that photo) 5x White LED
5x Yellow LED
5x Blue LED
5x Green LED
5x Red LED
1x RGB LED
5x 22pf Ceramic Capacitor
5x 104 Ceramic Capacitor
2x Photoresistor
1x Thermistor
5x Diode Rectifier (1N4007)
2x Electrolytic Capacitor(10UF 50V)
2x Electrolytic Capacitor (100UF 50V)
5x NPN Transistor (PN2222)
5x NPN Transistor (S8050)
1x Tilt Switch
5x Button (small)
1x 1 digit 7-segment Display
1x 4 digit 7-segment Display
1x Sound Sensor Module
1x LCD1602 Module (with pin header)
1x IC L293D
1x IC 74HC595
1x Active Buzzer
1x Passive Buzzer
1x RTC Module
1x DHT11 Temperature and Humidity Module
2x Potentiometer
1x Rotary Encoder Module
1x Joystick Module
1x Keypad Module
1x 5V Relay
1x IR Receiver Module
1x UNO R3 Controller Board
1x Breadboard
1x Servo Motor (SG90)
1x Stepper Motor
1x ULN2003 Stepper Motor Driver Board
1x Prototype Expansion
1x Power Supply Module
1x HC-SR501 PIR Motion Sensor
1x Ultrasonic Sensor
1x GY521 Module
1x 3V Motor
1x MAX7219 Module
1x Remote
1x 9V 1A Power Supply
1x 65 Jumper Wire
1x Water Lever Sensor
1x USB Cable
1x 9V Battery with DC
1x RC522 RFID Module
10x Resistor (10R
10x Resistor (100R)
10x Resistor (220R)
10x Resistor (330R
10x Resistor (1K)
10x Resistor (2K)
10x Resistor (5K1)
10x Resistor (10K)
10x Resistor (100K)
10x Resistor (1M)
20x Female-to-male Dupont Wire
