if (state == LOW) {
digitalWrite(ledPin, HIGH);
// i want here delay 4sec only here! if i put{ delay(4000);} the delay is going and to if (state == HIGH) how i do this?
esc.writeMicroseconds(2300);
if (state == HIGH){ digitalWrite(ledPin, LOW);
esc.writeMicroseconds(1000);
if (voltage <11.00) { digitalWrite(ledPin, LOW);
static unsigned long DelayTimer;
int state = digitalRead(hallSensorPin);
int sensorValue = analogRead(A0);
float voltage = (5 * sensorValue * (R1 + R2)) / (1024 * R2);
Serial.println(voltage);
delay(100);
if (state == LOW) {
if ((millis() - DelayTimer) >= (4000)) {// waits until the DeltaT of millis() and DelayTimer exceed 4000 miliseconds
if (state == HIGH) {
DelayTimer = millis(); // Sets the delay DelayTimer to start over as long as state == HIGH
if (voltage < 11.00) {
one more problem that i still have it is the read voltage if the arduino it is Connected to the computer USB and it is open the Serial monitor The volts are read correctly but if the arduino it is not connected to pc and i give it power from battery Does not read the volts correctly about -3 volts!
I write all the code from the beginning to see! Sorry for my bad English...
int state = digitalRead;
delay(100);
if (state == LOW) {
esc.Microseconds(1000);
this sounds more like a electrical issue rather than a programming issue.
Schematic with analog input wiring and battery voltage would be necessary for me to evaluate.
Z
zhomeslice:
Z
yes! Input Voltage (recommended) 7-12V
Input Voltage (limit) 6-20V
i gave 5.35 volts...! I gave him over 6v and works correctly!
one more ask
// i want, if read once voltage <11 And execute the other two commands, if read again over 11V do not star the motor. i want to stay [esc.writeMicroseconds(1000);] to must Disconnect arduino from battery and put again to new battery to have bigger volts. because When ιit is marginally in the volt to stop the motor it is star and after 1sec stop And this is done for a long time.
xenofon:
one more ask
I'm glad you have discovered the voltage reading problem.
I did not understand your sequence. Please generate some code or describe it differently to help us see what you are thinking.
Z
zhomeslice:
Z
Hi! thank you.
if (voltage < 11.00) // if reads this once {
esc.writeMicroseconds(1000); // forever! Even if the volts go up again.
"forever" until uno power is reset?
while(1){ // locks in loop and will never release!
if(digitalRead(releasePin) == LOW) break; // you can break the loop with this
Z
the firs code works fine ,the The second does not work [releasePin was not declared in this scope]
pinMode(ledPin, OUTPUT);
pinMode(hallSensorPin, INPUT);
esc.attach(9);
esc.Microseconds(1900); // i want this command run for 6sec
esc.Microseconds(1000); // and this for 2sec
delay(50);
esc.attach(9);
esc.writeMicroseconds(1900); // i want this command run for 6sec
esc.writeMicroseconds(1000); // and this for 2sec
These are Blink without delay timers just manipulated differently this runs in the setup so it only gets 1 chance so i use a while loop that breaks after the blink without delay time expires.
Note that this will execute the esc.writeMicroseconds(1900); over and over very rapidly during the time period!
esc.attach(9);
unsigned long _ATimer;
_ATimer = millis() ;
while ((millis() - _ATimer) < (6000)) {
while ((millis() - _ATimer) < (2000)) {
delay(50);
zhomeslice:
esc.attach(9);
delay(50);
