motor timing problem
I have built the hardware for a mobile platform, it runs on continuous rotation servos,the problem I'm having is with timing, I'm trying to implement a timer based movement cycle so as not to use delay(). with the code i currently have the servos are only moving in the forward movement
// robot movement 1.0
//servo
#include <Servo.h>
Servo right_servo;
Servo left_servo;
//speaker
const int speaker = 5;
//movement timer
int inUse = 0;
const int forwardUse = 1;
const int reverseUse = 2;
long previousMillis = 0;
  right_servo.attach(11);
  left_servo.attach(10);
  pinMode(speaker, OUTPUT);
  forward(1000);
  reverse(1000);
void halt()
  right_servo.write(90);
  left_servo.write(90);
void forward(long time)
  if(inUse == 0 || inUse == forwardUse) // check if it is in use by other movement
    right_servo.write(0);
    left_servo.write(180);
    inUse = forwardUse;
      if(currentMillis - previousMillis > time) // if timer has run out stop movement reset inUse and return to loop
          halt();
          inUse = 0;
          return;
void reverse(long time)
  if(inUse == 0 || inUse == reverseUse)  // check if it is in use by other movement
    right_servo.write(180);
    left_servo.write(0);
    inUse = reverseUse;
          halt();
          inUse = 0;
          return;
any help on this would be great, im trying to find an answer on my own but i must be missing something.
You need to reset previousMillis = currentMillis if timer has run out.
Check if what is in use?
    inUse = forwardUse;
ALL variables involved in measuring time should be unsigned long, unless you live in a universe where time runs backwards.
time is a lousy name. runTime, maybe.
And, yeah, what Henry said.
