Motor to control needles (like a clock)
Hi everyone,
I don't know much about Arduino, but I think it could answer to my need. I thus hope you could help me !
I am on a project which requires to have and control some "clocks", that is to say a basic dial and 2 needles. However, the needles should have the same length and be able to move independently. Besides, I would like to be able to control every single needle (their angles).
My project is very similar to the Ham Yard Hotel's clock, made up of 135 clocks :
https://www.humanssince1982.com/a-million-times-135-ham-yard-clock
So the question is : do you have an idea for the adequate material ? (Motor, Arduino card, clock...)
Ideally, the dials would be 5 and 20cm long.
I didn't find anything interesting on Google, but perhaps you could help me.
Thank you very much !
Seems the first step for you is to disassemble a clock and see how coaxial shafts are made and how they may be part of your project. The mechanical part of your project is rather complex. Do you have a shop where you can produce the mechanical components?
Paul
Had the same issue looking for a twin or dual shaft stepper for you.
Think you would have to use both a hollow rod and a smaller spindle approach.
I would think they did each one with a dual shaft and two small belts to independaNT PULLEY SYSTEM.
A shaft within a shaft so to speak.
Bob.
EDIT
Scaled up clearly.
Each dial pointer requires a separate stepper motor. It may be that you can buy the basic mechanism somewhere -- contact the artists behind the Humans Since 1982 project.
Fantastic idea, and works of art!
Sounds familiar to another thread. OK found it.
https://forum.arduino.cc/index.php?topic=642900.0
Thank you for each of your answers, it's very helpful !
The other topic seems indeed very similar to this one, so I will check it and reply here (or directly there) if I find new elements.
Have a nice day ! =)
