Motor voltage drops when using two buttons
I want to control a linear actuator 12v with my UNO and motor controller NH3SP30: GitHub - bmellink/VNH3SP30: Arduino Library for VNH3SP30 and VNH5019A-E motor drivers , I have connected the buttons using this guide: https://www.arduino.cc/en/Tutorial/BuiltInExamples/Button
The buttons is connected to pin2 and pin7. I want the motor to move forward when button 1 is pressed down and backwards when button 2 is pressed down. It all works fine but the motor runs slow and is not getting the full 12v, only around 5-6 volts. When removing one button in the code the motors runs at full speed, until stop.
My thought is that it has something to do with the “else” saying that motor should go down to speed 0 if the button is not pressed, but I am new to code so not sure, just a guess. It is almost as it brakes the motor and interfere with the speed (+400) and (-400) command.
 * VNH3SP30 motor driver library - demo for a single motor
 * This library is free software; you can redistribute it and/or
 * modify it under the terms of the GNU Lesser General Public
 * License as published by the Free Software Foundation; either
 * version 2.1 of the License, or (at your option) any later version.
 * Created 2 June 2019 Bart Mellink
#include <VNH3SP30.h>
VNH3SP30 Motor1;    // define control object for 1 motor
const int buttonPin1 = 2;     // the number of the pushbutton pin
const int buttonPin2 = 7;     // the number of the pushbutton pin
int buttonState = 0;         // variable for reading the pushbutton status
// motor pins
#define M1_PWM 3    // pwm pin motor
#define M1_INA 4    // control pin INA
#define M1_INB 5    // control pin INB
#define M1_DIAG 6   // diagnose pins (combined DIAGA/ENA and DIAGB/ENB)
#define M1_CS A0    // current sense pin
  Motor1.begin(M1_PWM, M1_INA, M1_INB, M1_DIAG, M1_CS);    // Motor 1 object connected through specified pins
  pinMode(buttonPin1, INPUT);   // initialize the pushbutton pin as an input:
  pinMode(buttonPin2, INPUT);   // initialize the pushbutton pin as an input:
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin1);
  // check if the pushbutton 1 is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // Turn motor on backward:
  Motor1.setSpeed(-400);
    // Turn motor off:
  Motor1.setSpeed(0);  }
  buttonState = digitalRead(buttonPin2);
  // check if the pushbutton 2 is pressed. If it is, the buttonState is HIGH:
    // Turn motor on forward:
  Motor1.setSpeed(+400);
    // Turn motor off:
How are the buttons connected? Do you have pull-down resistors between the pin and GND to make certain that they are truly LOW when not pressed?
Steve
slipstick:
Steve
Yes 10K resistor connected between button and GND.
I Have attached a drawing on the connections, hope it makes sens.
I measured the output now, and it is almost 2,6 V when not pressed, so apparently is not truly low when not pressed, any idea why?
The program gives conflicting commands to the motor.
If one button is HIGH, the program says to turn one direction, and if the other button is LOW, the program says to stop.
What do you think the motor controller supposed to do in that situation? What happens if both buttons are pushed, and the motor is told to go in both directions?
You need to decide exactly what the buttons are supposed to do, and program accordingly. There are four possible states of two buttons, and they all need to be considered.
Aha, so something like
If button 1 is high and button 2 is low = spin forward
If button 2 is high and button 2 is high = spin backwards
I think I got it. Now it outputs +12v and -12v, but still 2.6v when nothing is pressed. Is that normal?
int buttonState1 = 0;         // variable for reading the pushbutton status
int buttonState2 = 0;         // variable for reading the pushbutton status
// motor pins
  buttonState1 = digitalRead(buttonPin1);
  buttonState2 = digitalRead(buttonPin2);
  if ((buttonState2 == HIGH) && (buttonState1 == LOW)) {
  if ((buttonState1 == HIGH) && (buttonState2 == LOW)) {
// check if nonn of the buttons is pressed
  if ((buttonState2 == LOW) && (buttonState1 == LOW)) {
    // Turn motor off:
  Motor1.setSpeed(0);
Have you tried running the example program to see if your driver and actuator are OK? Set the actuator in middle position first, I changed the delays to 1 second so (hopefully) the actuator won’t run to the end of travel.
// motor pins
  Serial.println("3/4 speed forward");
  Motor1.setSpeed(300); // motor 3/4-speed "forward"
  delay(1000); // wait for 2 seconds
  Serial.print("Current="); Serial.println(Motor1.motorCurrent());
  Serial.println("Motor stop (coast)");
  Motor1.setSpeed(0); // motor stop (coasting)
  Serial.print("Current at stop="); Serial.println(Motor1.motorCurrent());
  Serial.println("Half speed backward");
  Motor1.setSpeed(-200); // motor half-speed "backward"
  Serial.println("Full speed backward");
  Motor1.setSpeed(-400); // motor full-speed "backward"
  Serial.println("Brake at 3/4 power");
  Motor1.brake(300); // motor brake at 3/4 power
  delay(10);
  Serial.print("Current during brake="); Serial.println(Motor1.motorCurrent());
  delay(4000); // wait for 4 seconds
  Serial.print("Current after brake="); Serial.println(Motor1.motorCurrent());
Don't try to instantly switch between rotating forward and backward. Doing so causes an enormous current draw and can damage the motor and motor driver.
JCA34F:
  • VNH3SP30 motor driver library - demo for a single motor
  • This library is free software; you can redistribute it and/or
  • modify it under the terms of the GNU Lesser General Public
  • License as published by the Free Software Foundation; either
  • version 2.1 of the License, or (at your option) any later version.
  • Created 2 June 2019 Bart Mellink
// motor pins
 Serial.println(“3/4 speed forward”);
 Motor1.setSpeed(300); // motor 3/4-speed “forward”
 Serial.print(“Current=”); Serial.println(Motor1.motorCurrent());
Serial.println(“Motor stop (coast)”);
 Serial.print(“Current at stop=”); Serial.println(Motor1.motorCurrent());
Serial.println(“Half speed backward”);
 Motor1.setSpeed(-200); // motor half-speed “backward”
Serial.println(“Full speed backward”);
 Motor1.setSpeed(-400); // motor full-speed “backward”
Serial.println(“Brake at 3/4 power”);
 delay(10);
 Serial.print(“Current during brake=”); Serial.println(Motor1.motorCurrent());
 Serial.print(“Current after brake=”); Serial.println(Motor1.motorCurrent());
Yes it works great, but same 3V to the motor after it is set to:
jremington:
Thanks for the tip, so adding delay in the beginning of each start I guess will solve that?
Something like this?
// check if the pushbutton 1 is pressed ad if: run motor forward
  // Brake Motor
  delay(10);
  //Turn motor on forward:
// check if the pushbutton 2 is pressed ad if: run motor backward
  // Brake Motor
  delay(10);
  //Turn motor on backward:
// check if both buttons is pressed and if: forward motor 2 sec
  if ((buttonState2 == HIGH) && (buttonState1 == HIGH)) {
  // Brake Motor
  delay(10);
  // motor forward
  delay(2000);
  // check if nothig is pressed and if: Stop motor
    // Turn motor off:
  Motor1.setSpeed(0);
No. You have to command the motor to stop, and wait until it does, before you send the command to rotate in the reverse direction.
