A brief introduction as this is my first post.
Please let me know if I have done something in this post that is incorrect.
I have always been interested in learning to program in c++ but I have never taken the leap, until now. I am known for jumping in head first and I believe that this simple project has turned into that scenario.
I started this endeavor with the thought of saving a few dollars by making my own head light modulator / brake light flasher instead of paying >$100.
Once I learned the very basics and watched a few videos viola, a functioning device for around $15!
I then decided to take it a step further and try my hand at adding a cruise control function.
Before you get to reading my current coding, understand that while I do understand 95% of whats in it, most of it is copying others handy work or examples and modifying it to suit my needs.
That brings us to the here and now…
I have everything working as it should except for a “cruiseCancel” IE when the brake is applied, set cruiseEnable to LOW -immediately!-
I have tried if commands before and after the setSWdown portion as well as at the beginning of the loop and the end.
I have tried an else statement after the setSWdown portion as well.
Everything I try seems to set my cruiseEnable to HIGH no matter the state of the power to the circuit or the state of the brake.
As for the circuit, I have included a graphic, before you ask, My bike uses a combination tail light and brake light wire. while the brake is applied it is at nominal voltage, while the brake is not applied, it rests at 9.4 volts.
I currently have a breadboard and arduino UNO set up and have verified that the code is working except for a cancel command.
I have the code in to be able to operate a stepper driver but I don’t have one yet and want to do this one step at a time.
Please don’t tell me how horrible my code looks, I am going to clean it up more as I learn!
Yes I know that this is dangerous.
Yes I am going to implement mechanical bypasses.
Yes I know this a in depth sketch for my first one.
Yes I understand that these boards and circuits can fail.
No I don’t need to be reminded that its dangerous.
const int brakeLight = 7;
const int brakeSwitch = A0;
const int highBeam = 6;
const int highBeamSwitch = 8;
int brakeSwitchState = analogRead(brakeSwitch);
int brakeState = HIGH;
int counter = 0;
int blinkCount = 7;
int highBeamState = LOW;
int highBeamSwitchState = 0;
int dayLight = 0;
int dayLightPin = A1;
int dusk = 200;
int voltageThreshold = 300;
int hall = 3;//IRQ1
int cruiseEnable = 13;
int cruiseStep = 10;
int cruiseDirection =11;
int setSwitch = 12;
int cruisePower = digitalRead(9);
int gap;
int setSWdown;
volatile unsigned int speedTick=0;
volatile unsigned int prevSpeedTick;
volatile unsigned int speedSet;
volatile unsigned int tick;
void hallISR() {
prevSpeedTick = speedTick; // buffer so speedTick can be used as prevSpeedTick
during compares
speedTick = 0;
unsigned long previousMillis = 0;
unsigned long previousMillis1 = 0;
const long interval = 100;
const long interval1 = 120;
//Void Setup-------------------------------------------------------------------------------------------
pinMode(brakeLight, OUTPUT);
pinMode(highBeam, OUTPUT);
pinMode(brakeSwitch, INPUT);
pinMode(hall, INPUT);
pinMode(cruiseEnable,OUTPUT);
pinMode(cruiseStep,OUTPUT);
pinMode(cruiseDirection,OUTPUT);
pinMode(setSwitch, INPUT);
cli(); // stop interrupts
TCCR2A = 0; // set entire TCCR2A register to 0
TCCR2B = 0; // same for TCCR2B
TCNT2 = 0; // initialize counter value to 0
// set compare match register for 2000 Hz increments
OCR2A = 249; // = 16000000 / (32 * 2000) - 1 (must be <256)
// turn on CTC mode
TCCR2B |= (1 << WGM21);
// Set CS22, CS21 and CS20 bits for 32 prescaler
TCCR2B |= (0 << CS22) | (1 << CS21) | (1 << CS20);
// enable timer compare interrupt
TIMSK2 |= (1 << OCIE2A);
sei(); // allow interrupts
// HARDWARE INTERRUPT on pin 3(hall effect) attached to hall effect device
attachInterrupt(digitalPinToInterrupt(hall), hallISR, FALLING);
ISR(TIMER2_COMPA_vect)
speedTick=speedTick+1;
//Void Loop--------------------------------------------------------------------------------------------
Serial.println(brakeSwitchState);
delay(1);
dayLight = analogRead(dayLightPin);
setSWdown = digitalRead(setSwitch);
//Cruise Control---------------------------------------------------------------------------------------
// THIS IS THE PART where I'm having difficulty ---------------------------------------------------
if (setSWdown == LOW)
speedSet = prevSpeedTick;
gap = speedSet / 40;
digitalWrite(cruiseEnable,HIGH);
if (prevSpeedTick > speedSet + gap) //too slow
openThrottle();
if (prevSpeedTick < speedSet - gap ) //too fast
closeThrottle();
//Brake Flasher----------------------------------------------------------------------------------------
if ((brakeSwitchState > voltageThreshold) && (counter <= blinkCount)) {
if (currentMillis - previousMillis >= interval) {
if (brakeState == LOW) {
brakeState = HIGH;
brakeState = LOW;
counter++;
digitalWrite(brakeLight, brakeState);
if (brakeSwitchState > voltageThreshold){
digitalWrite(brakeLight, HIGH);
digitalWrite(brakeLight, LOW);
if(brakeSwitchState < voltageThreshold) {
counter = 0;
//Headlight Modulator----------------------------------------------------------------------------------
highBeamSwitchState = digitalRead(highBeamSwitch);
if ((dayLight >= dusk) && (highBeamSwitchState == HIGH)) {
unsigned long currentMillis1 = millis();
if (currentMillis1 - previousMillis1 >= interval1) {
previousMillis1 = currentMillis1;
if (highBeamState == LOW) {
highBeamState = HIGH;
digitalWrite(highBeam, highBeamState);
if (highBeamSwitchState == HIGH) {
digitalWrite(highBeam, HIGH);
digitalWrite(highBeam, LOW);
//Stepper Control--------------------------------------------------------------------------------------
void openThrottle ()
digitalWrite(cruiseDirection,HIGH);
digitalWrite(cruiseStep,HIGH);
delay(1);
digitalWrite(cruiseStep,LOW);
delay(1);
void closeThrottle ()
digitalWrite(cruiseDirection,LOW);
delay(1);
delay(1);
