Hi All,
I'm building a data logger for my motorcycle and this is my first real foray into electronics. What I currently have is a Uno R3 with a4 digit 7segment display and two neopixel sticks for displaying the tach and settings. Currently I'm sensing the RPM's with a ?RC low pass filter? directly from the ignition circuit to an interrupt that increments a counter I read and rest in the loop and it works great.
Now, I'm adding a gyroscope/accell breakout board, GPS(I'd like to read the gps at 10Hz), and SD card to log the data from the sensors to. Using all of the examples, I tested everything and they all work independently.
As you can guess, I'm out of sram. While I wait on a mega (tried pairing down the libs, made progress but not enough. the sd / gps shield example took up ~1800 bytes before I added anything else; that is a realllly poor starting point and my C++ is nothing to write home about) I'm planning my next steps. I would like to use hall effect sensors to count RPM's on each wheel to calculate slippage, and allow me to calculate what gear I'm in by combining RPM and wheelspeed. The hall sensors should be ~16Hz max(18inch radius, top speed <100mph). In addition I would like to add throttle and brake position sensors (two brake sensors one front and one rear). I'm not sure how to do this yet but I'm thinking some type of potentiometer for an analog signal.
Now that you have my context, my problem:
I need to count pulses from three inputs, rpm, front wheel hall, rear wheel hall.
My tentative solution is to take three shift registers(sensor buffers), attach all of their outputs to one shift register in reverse(ardy interface), tell the buffer register to dump it's contents to the latch on the shift registery setup in reverse that is doing a parallel read, then read the signal pin of that shift register to get the count, reset everything, move to the next sensor lather, rinse repeat. Am I overlooking a simpler solution? It seems like doing a digital, read on something that just counts digital input pulses shouldn't be this difficult to offload?
Assuming I can completely quit using interupts, and rely using the GPS in soft serial to buffer it's output (big question). The pseduo code for my loop would look something like this:
void loop(){
//currently my dataLoopInterval is 10ms, this may not work with the write to the SD + all the reads
//as long as this takes less than 100ms, it should be fine I'll adjust it to a multiple of 100 as needed
//this method could also drift, should I use a timer interupt?
if(currentTime >= (loopTime + dataLoopInterval )){ //10ms
//update the rolling average of the last 25 ticks with however rpms happened in the last ~10ms tick
updateRpm();
if (GPS.newNMEAreceived()) char *gpsSentence = readGps();
lsm.read(); // put the most recent gyro / accel data from their respective buffers into properties
//accel info
int ax = lsm.accelData.x;
int ay = lsm.accelData.y;
int az = lsm.accelData.z;
//lean angle info
int gx = lsm.gyroData.x;
int gy = lsm.gyroData.y;
int gz = lsm.gyroData.z;
//frontWheel a digital pin connected to the shift reg buffering the rear wheel
byte fw = shiftRegRead(frontWheel);
//rearWheel a digital pin connected to the shift reg buffering the front wheel
byte rw = shiftRegRead(rearWheel);
logData(gpsSentence, rpm, gx, gy, gz, ax, ay, az, rw, fw); //save it all to the SD; rpm is a global
loopTime = currentTime;
//every 100ms write the current RPM's out to the displays
if(currentTime >= (displayTime + renderLoopInterval)){ //100ms
writeLightBar();
writeSegDisplay();
displayTime = currentTime;
Sorry for a wall of text and thank you for taking the time to read this far if you made it! If you have any feedback about the approach I'd apprecate it! (Even if it is have you googled xyz? I don't know what I'm missing)
