Hello everyone!
I have been looking for the rules of this forum to make sure I wasn't going to make anyone unhappy but I haven't had much luck. I hope I am doing this right, in case please let me know and I'll rectify.
Quickly about me.
I'm Ciro, south Italian based in London UK. I've studied computer engineering and I believe I have the basic knowledge to figure this maker thing out.
The idea.
Last night getting back home from work with my Ducati monster 696 I was reflecting on how much technology this old machine has that many similar don't have still today, but at the same times is also missing some pretty basic things that have been standard for decades.
For instance: no gear indicator, no fuel level gauge and no emergency indicator lights.
I don't really miss any of that, but I thought I'd do a quick Google search to see if any of it can be helped.
For the gear indicator you can pretty much buy a kit that might or might not be easy to install and might or might not work decently, that comes with this old school segment display that you'll need to put somewhere. Costs about 56£. ![]()
For the emergency lights I've read on the manual for my alarm that with a certain buttons combo on the fob I can get the four indicators to blink continuously but I don't remember the combo, nor if I need to have the bike on or off, nor have I got the will to go check the manual again.
For the fuel level... well let's just ignore that for now. ![]()
But then I got to think. And I got to Google again. And I found this guy that with an Arduino, 3 switches and a display made his own gear indicator.
It was just a concept and he wasn't going to actually install it on his bike, but it did make sense.
Now, I have a fairing right in the centre of the tank that has a hole where there used to be the led for the alarm. Under that hole there's a decent amount of empty space and I get the added bonus of learning stuff, which is always nice.
So the project.
If I could, using an small Arduino, with a small TFT display make my own gear indicator, I could place it in stead of that ugly empty hole and, I would be open to potentially implement more tech into it.
Only problem is I don't know the platform all that well, so as a good engineer instead of diving in blind I thought I'd get in touch with who knows and make sure I'm doing everything right.
My solution so far Is using an ARDUINO NANO RP2040 CONNECT (ABX00052) with a round LCD from waveshare, two switches for gear+ and gear-, and syphoning the signal for neutral from the original dashboard.
If I understand well that that Arduino might be a bit of an overkill for this project, but I want to have room to implement other things in the future, like the emergency lights thing for example, and maybe a bit of data recording from those built in acceleration sensors and other things.
The questions
Firstly do you think I'd have any problems having that Arduino work with that screen? As far as my research suggests it should go as smooth as custard, but you never know.
Second, my current last version projection would see the board displaying a little boot animation, then go straight to gear display in real time. A few buttons to go in and out and navigate the menu, and eventually simultaneously read, record and send data over Bluetooth from maybe 10 sensors, the onboard ones and a few linear ones at most, to an Android phone whilst still giving me the gears. Finally one button to turn on my emergency indicators. Do you think it has the horsepower to run all of that?
I guess the most is going to be sending that data over, because the rest will pretty much be built on interrupt.
Thanks for reading me and in advance for your help.
Cheers,
Ciro
EDIT:
First fully working prototype is complete, here is the code and all instructions.
* Arduino gear indicator
* Author: Ciro Napolitano (c-rabbit)
* instructions
* This will work on an arduino nano and a 128x64 OLED display compatible with Adafruit's library.
* Just wire the display as instructed on the manual, then connect 3 10k resistors from pins 2, 6 and 9 to GND.
* After that you will need 2 hall effect sensors (or push buttons) to place near the shift lever so that they
* activate when you shift, and an octocoupler connected in parallel with the neutral light bulb on your
* dashboard.
* Connect the 5V and ground to your hall sensors and the third pins back to pins 2 and 6.
* Connect the 5V to your octocoupler, and the other pin back to pin 9.
* Make sure your board has power and enjoy it!
//Setting up for the screen
//libraries needed
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//screen dimentions
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
//defining the screen address here
#define SCREEN_ADDRESS 0X3C
//telling the system we have an SSD1306 screen without reset pin (-1)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
#define theia_logo_width 128
#define theia_logo_height 64
//Bitmaps for the boot animation
static const unsigned char PROGMEM theia_logo0[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0xff, 0xff, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0x80, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0x80, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0};
static const unsigned char PROGMEM theia_logo1[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x1d, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x11, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo2[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xbf, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x1f, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x10, 0x1f, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0x80, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo3[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x83, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x3, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x10, 0x3, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo4[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x7f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x7f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x0, 0x7f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x10, 0x0, 0x7f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo5[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x1, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x1, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x0, 0x1, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x10, 0x0, 0x1, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo6[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xfe, 0x3f, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x0, 0x3f, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x0, 0x3f, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x0, 0x0, 0x3f, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x10, 0x0, 0x0, 0x3f, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo7[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xfe, 0x7, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x0, 0x7, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x0, 0x7, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x0, 0x0, 0x7, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x10, 0x0, 0x0, 0x7, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo8[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xfe, 0x0, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x0, 0x0, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x0, 0x0, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x0, 0x0, 0x0, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo9[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xfe, 0x0, 0x1f, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x0, 0x0, 0x1f, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x0, 0x0, 0x1f, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x0, 0x0, 0x0, 0x1f, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo10[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xfe, 0x0, 0x3, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x0, 0x0, 0x3, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x0, 0x0, 0x3, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1c, 0x0, 0x0, 0x0, 0xf, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo11[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xfe, 0x0, 0x0, 0x3c, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x0, 0x0, 0x0, 0x3c, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x0, 0x0, 0x0, 0x3c, 0x0, 0x0, 0x0, 0x0, 0x0,
static const unsigned char PROGMEM theia_logo12[] = {
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0x80, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
//now let's setup for the input
//first let's choose the pins we will be using for the three inputs
const int gearUp = 2;
const int gearDown = 6;
const int neutralSignal = 9;
#define DEBOUNCE 50 //a little debounce never killed anyone
//initialise the statuses of the 3 inputs
int upState = 0, downState = 0, neutralState = 0;
//define the symbols for the gears
char gearSymbol[8] = {'1', 'N', '2', '3', '4', '5', '6', 'U'};
int gear = 7;
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //starts the screen
//setup all the pins correctly
pinMode(gearUp, INPUT);
pinMode(gearDown, INPUT);
pinMode(neutralSignal, INPUT);
// Clear the buffer.
display.clearDisplay();
// Draw the bitmaps on the screen for the boot animation
display.drawBitmap(0, 0, theia_logo0, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo1, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo2, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo3, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo4, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo5, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo6, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo7, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo8, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo9, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo10, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo11, theia_logo_width, theia_logo_height, 1);
display.display();
delay(100);
display.drawBitmap(0, 0, theia_logo12, theia_logo_width, theia_logo_height, 1);
display.display();
delay(2000);
//initialise serial for monitoring
void DisplayGear(){// I was using this bits of code a lot so i packed them in a function
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0, 0);
display.println("Current gear:");
display.setTextSize(6);
display.setCursor(50, 20);
display.println(gearSymbol[gear]);
display.display();
void loop() {// listen to the inputs and print current gear
upState = digitalRead(gearUp);
downState = digitalRead(gearDown);
neutralState = digitalRead(neutralSignal);
//if any of the inputs changed, do a bit of debounce and then act on the current gear accordingly
if (upState == HIGH){
delay(DEBOUNCE);
if (gear == 0 || gear == 1) //if you upshift from 1st or neutral you always go to second
gear = 2;
else if (gear > 1 && gear < 6)
gear++;
while (upState == HIGH){
upState = digitalRead(gearUp); // wait for the lever to be released
else if (downState == HIGH){
delay(DEBOUNCE);
if (gear == 1 || gear == 2) //downshifting from 2nd or neutral always goes to 1st
gear = 0;
else if (gear > 2 && gear < 7)
gear --;
while (downState == HIGH){
downState = digitalRead(gearDown); // wait for the lever to be released
else if (neutralState == HIGH){
delay(DEBOUNCE);
if (neutralState == HIGH){ //when there is the neutral signal you go to neutral
gear = 1;
while (neutralState == HIGH){
DisplayGear(); //since neutral is a continuous signal it needs to be printed immediately
neutralState = digitalRead(neutralSignal); // wait for the lever to be released
DisplayGear();
