Hi all, I'm new to this forum, and to be honest new to the Arduino entirely. But I'm not new to building things:
That's my bike, it's an 87 Ninja 750. I bought it as a basket case, and have spent the last few years, slowly piecing it back together. Ignore my buddy walking towards my camera, unless you like PBR. Which I do!
I'm going to have 2 strips side by side on each turn signal, and I want them to pulse similar to Knight Rider.
The strips can be broken up into sections of 3, which I'll be doing.
Here's where I need help:
Can a single Arduino run both turn signals independently? And handle the hazard light function? I do want to stay moderately legal. Since it's in the bike, what else could I use it for?
Which Arduino would I need to purchase?
I've found the blikenlight code for the Knight Rider effect, and it seems like that would be a good choice to use. I'm not a computer programmer so what else would need done to make my project happen.
Is this even doable? Or should I use something different?
Yeah that should be too hard. Just need a button or something to tell it to turn on the blinker when needed. Biggest problem woudl eb getting the blinker to shut off after a turn (though most bikes don't do that anyways if i remember)
You could probably pull it all off with a regular uno, though if you don't want a big controller sitting on your bike somewhere you could try with one of the smaller arduino models.
Perhaps learning a bit of the core could help, tutorials are always helpful. Biggest worry with this would be having enough power for the arduino and the LEDs to run for a while. You'll probably end up needing to run the rig off of that bikes battery (if it has one) or having a battery pack you gotta take off and plug in at home to run it.
Thanks for the guidance! I was going to go ahead and wire the arduino into the power supply of the bike, and after figuring out a bit more of what it can do: using it for a few more things than running my turnsignals.
I was going to use the handlebar switch, which isn't too hard to work with. And you are correct, most motorcycles aren't self-canceling.
ATTiny are smaller MCU's than the ATMegas the Arduino's run on, but they're mostly compatible.
They're about half the price, just as fast but fewer than half the legs. But, I think, still more than you need.
Consider that as a stand-alone you can pack the project however you got space for the parts and only for the cost of parts, not a whole Arduino. You could probably fit the whole 'brains' onto a cheap 20 or so pin socket using the socket as a kind of PCB. They ain't called Tiny for nuthin! Mouser used to have them 10 for about $1.35 each months ago, if anything they might be cheaper now.
