Tengo este codigo pero no funcionan correctamente los motores solo funcionan dos de 4 podria ayudarme soy nuevo en el tema de arduino gracias
#include <Servo.h> //servo library
Servo myservo; // create servo object to control servo
int Echo = A4;
int Trig = A5;
int in1 = 6;
int in2 = 7;
int in3 = 8;
int in4 = 9;
int ENA = 5;
int ENB = 11;
int ABS = 110;
int rightDistance = 0,leftDistance = 0,middleDistance = 0;
void _mForward()
analogWrite(ENA,ABS);
analogWrite(ENB,ABS);
digitalWrite(in1,HIGH);
digitalWrite(in2,LOW);
digitalWrite(in3,HIGH);
digitalWrite(in4,LOW);
Serial.println(“go forward!”);
void _mBack()
digitalWrite(in1,LOW);
digitalWrite(in2,HIGH);
digitalWrite(in3,LOW);
digitalWrite(in4,HIGH);
Serial.println(“go back!”);
void _mleft()
Serial.println(“go left!”);
void _mright()
Serial.println(“go right!”);
void _mStop()
digitalWrite(ENA,LOW);
digitalWrite(ENB,LOW);
Serial.println(“Stop!”);
/Ultrasonic distance measurement Sub function/
int Distance_test()
digitalWrite(Trig, LOW);
delayMicroseconds(2);
digitalWrite(Trig, HIGH);
delayMicroseconds(20);
float Fdistance = pulseIn(Echo, HIGH);
Fdistance= Fdistance/58;
return (int)Fdistance;
myservo.attach(3);// attach servo on pin 3 to servo object
pinMode(Echo, INPUT);
pinMode(Trig, OUTPUT);
pinMode(in1,OUTPUT);
pinMode(in2,OUTPUT);
pinMode(in3,OUTPUT);
pinMode(in4,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(ENB,OUTPUT);
_mStop();
myservo.write(90);//setservo position according to scaled value
middleDistance = Distance_test();
#ifdef send
Serial.print(“middleDistance=”);
Serial.println(middleDistance);
#endif
if(middleDistance<=30)
_mStop();
_mBack();
_mStop();
myservo.write(5);
rightDistance = Distance_test();
#ifdef send
Serial.print(“rightDistance=”);
Serial.println(rightDistance);
#endif
//delay(500);
// myservo.write(90);
myservo.write(180);
leftDistance = Distance_test();
#ifdef send
Serial.print(“leftDistance=”);
Serial.println(leftDistance);
#endif
myservo.write(90);
if(rightDistance>leftDistance)
_mright();
delay(230);
else if(rightDistance<leftDistance)
_mleft();
delay(230);
else if((rightDistance<=30)||(leftDistance<=30))
_mBack();
_mForward();
_mForward();
