I was hoping to control an Alps motorised potentiometer using the mega board I have, when I built the DAC I put in a motorised pot just in case this day came.
My problem is I have not been able to find any information on how to implement it, can you help?
The best I can tell you is it is a DC motor that is rated at 4.5volts 150ma max connections are straight to motor only 2 wires. I'm thinking if I just connect a couple of solid state non latching relays with reversed polarity one one & a 4.5v SMPS PSU that may work??
