Motorized fader MIDI control surface for pro tools
okay. so i'm trying to make a HUI control surface for pro tools involving a motorized fader that will control the pro tools fader. the arduino reads pro tools beautifully and it updates the physical fader with little issues, however it doesn't write TO protools quite as well, if i move the fader it will update pro tools to the new position, then physical fader will immediately jump back to the last position and kinda stager up to the new position.
this is my code:
i used cody hazelwoods code as a starting point so some credit goes to him, a fare bit had to be changed for pro tools and hui protocol. been struggling with this one for a few days now. any thoughts?
For better assistance, you should post your code here instead of making folks download it from a cut and paste link. Just paste it between code tags like such [code]your code here[/code]. Or you can use the copy for forum feature under edit in the IDE.
If it is too long, choose modify under your post above. Toward the bottom there is an area where you can upload your ino file as an attachment.
#include<MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#include<CapacitiveSensor.h>
#include <LiquidCrystal.h>
#define ControlChange 0xB0
#define NoteOn 0x90
//Arduino Pin Assignments
const int motorDown    = 5;   //H-Bridge control to make the motor go down
const int motorUp      = 6;   //H-Bridge control to make the motor go up
const int wiper        = A0;   //Position of fader relative to GND (Analog 0)
const int touchSend    = 4;   //Send pin for Capacitance Sensing Circuit (Digital 7)
const int touchReceive = 2;   //Receive pin for Capacitance Sensing Circuit (Digital 8)
const int channelLeft = 12;     // the number of the channelLeft (Digital 12) pin
const int channelRight = 13;     // the number of the channelRight (Digital 13) pin
//Variables
double   faderMax        = 0;     //Value read by fader's maximum position (0-1023)
double   faderMin        = 0;     //Value read by fader's minimum position (0-1023)
int      faderChannel    = 0;     //Value from 1-8
int      chLeftBtn       = 0;
int      chRightBtn      = 0;
int      faderPositionLoop;
bool     touched         = false; //Is the fader currently being touched?
bool     positionUpdated = false; //Since touching, has the MIDI position been updated?
String ascii = "";
String oldAscii = "";
bool compare = true;
//LCD pins
LiquidCrystal lcd(52, 50, 46, 44, 42, 40);
byte channel1LCD[]  {0xf0, 0x00, 0x00, 0x66, 0x05, 0x00, 0x10};
CapacitiveSensor touchLine = CapacitiveSensor(touchSend, touchReceive);
  Serial.begin(31250);
  MIDI.begin(MIDI_CHANNEL_OMNI);  //Receive messages on all MIDI channels
  MIDI.turnThruOff();             //We don't need MIDI through for this
  MIDI.setHandleSystemExclusive(handle_sysex);
  pinMode (motorUp, OUTPUT);
  pinMode (motorDown, OUTPUT);
  calibrateFader();
int newPosition;
  // update physical fader position
  checkTouch();                    // check if phyisical fader has been touched
  if (!positionUpdated) {           // if it has update midi to protools
    updateFaderMidi();
    newPosition = (((float)(analogRead(wiper) - faderMin) / (faderMax - faderMin)) * 16383);
    updateFader(faderPositionLoop);
    positionUpdated = true;
  else {
    faderPositionLoop = checkMIDI(); // run midi check and return fader position from protools
    updateFader(faderPositionLoop);      // update physical fader with midi info
void calibrateFader() {
  //Send fader to the top and read max position
  digitalWrite(motorUp, HIGH);
  digitalWrite(motorUp, LOW);
  faderMax = analogRead(wiper) - 5;
  //Send fader to the bottom and read min position
  digitalWrite(motorDown, HIGH);
  digitalWrite(motorDown, LOW);
  faderMin = analogRead(wiper) + 5;
// check for incoming midi signals
int checkMIDI() {
  static byte velocity1 = 0;
  static byte velocity2 = 0;
  static int faderPosition = 0;
  static int oldMidi = 0;
  if (MIDI.read()  && MIDI.getChannel() == 1 && MIDI.getType() == ControlChange && MIDI.getData1() == 0x00) // check for MSB
    velocity1 = MIDI.getData2();
  if (MIDI.read()  && MIDI.getChannel() == 1 && MIDI.getType() == ControlChange && MIDI.getData1() == 0x20)  // Check for LSB
    velocity2 = MIDI.getData2();
  faderPosition = (((velocity1 << 7) + velocity2) >> 4); //bitwise math to combine MSB and LSB
  return faderPosition ;   // remember to initialize using variable assignment with function call
void updateFader(int fposition) {
  if (fposition < analogRead(wiper) - 10 && fposition > faderMin && !touched) {
    while (fposition < analogRead(wiper) - 10 && !touched) {};  //Loops until motor is done moving
  else if (fposition > analogRead(wiper) + 10 && fposition < faderMax && !touched) {
    while (fposition > analogRead(wiper) + 10 && !touched) {}; //Loops until motor is done moving
void checkTouch() {
  int movedFader;
  //For the CapacitiveSensor comparison below,
  //700 is arbitrary and may need to be changed
  //depending on the fader cap used (if any).
  if (!touched && touchLine.capacitiveSensor(30) >= 3000) {
    touched = true;
    //Send MIDI Touch On Message
    MIDI.send(ControlChange, 0x0f, 0x00, 0x01);
    MIDI.send(ControlChange, 0x2f, 0x40, 0x01);
  else if (touched && touchLine.capacitiveSensor(30) < 3000) {
    touched = false;
    MIDI.send(ControlChange, 0x2f, 0x00, 0x01);
  if (touched) {
void updateFaderMidi() {
  static int oldValue = 0;                        // set old value to 0 only for first time
  int velocity = faderPosition();
  if (oldValue != velocity) {
    byte faderMSB = (velocity >> 7) ;               // get MSB value in 7 bit
    MIDI.send(ControlChange, 0x00, faderMSB, 0x01); // send MSB value
    byte faderLSB = (velocity & 0x7f);               // get LSB value
    MIDI.send(ControlChange, 0x20, faderLSB, 0x01); // send new value
    oldValue = velocity;
//Returns a MIDI pitch bend value for the fader's current position
//Cases ensure that there is a -infinity (min) and max value despite possible math error
int faderPosition() {
  int fposition = analogRead(wiper);
  int returnValue = 0;
  if (fposition <= faderMin) {
    returnValue = 0;
  else if (fposition >= faderMax) {
    returnValue = 16383;
  else {
    returnValue = ((float)(fposition - faderMin) / (faderMax - faderMin)) * 16383;
  return returnValue;
