Stepper.cpp - - Stepper library for Wiring/Arduino - Version 0.4
Original library (0.1) by Tom Igoe.
Two-wire modifications (0.2) by Sebastian Gassner
Combination version (0.3) by Tom Igoe and David Mellis
Bug fix for four-wire (0.4) by Tom Igoe, bug fix from Noah Shibley
Drives a unipolar or bipolar stepper motor using 2 wires or 4 wires
When wiring multiple stepper motors to a microcontroller,
you quickly run out of output pins, with each motor requiring 4 connections.
By making use of the fact that at any time two of the four motor
coils are the inverse of the other two, the number of
control connections can be reduced from 4 to 2.
A slightly modified circuit around a Darlington transistor array or an L293 H-bridge
connects to only 2 microcontroler pins, inverts the signals received,
and delivers the 4 (2 plus 2 inverted ones) output signals required
for driving a stepper motor.
The sequence of control signals for 4 control wires is as follows:
Step C0 C1 C2 C3
1 1 0 1 0
2 0 1 1 0
3 0 1 0 1
4 1 0 0 1
The sequence of controls signals for 2 control wires is as follows
(columns C1 and C2 from above):
Step C0 C1
1 0 1
2 1 1
3 1 0
4 0 0
The circuits can be found at
http://www.arduino.cc/en/Tutorial/Stepper
// set pin numbers:
const int dirPin = 10; // the number of the LED pin
// Variables will change:
int dirState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 0; // interval at which to blink (milliseconds)
#include "WProgram.h"
//#include "Stepper.h"
* two-wire constructor.
* Sets which wires should control the motor.
// ** One motor_Pin and direction_pin
Stepper::Stepper(int number_of_steps, int motor_pin_1/*, int motor_pin_2*/, int direction_pin)
this->step_number = 0; // which step the motor is on
this->speed = 0; // the motor speed, in revolutions per minute
this->direction = 0; // motor direction
this->last_step_time = 0; // time stamp in ms of the last step taken
this->number_of_steps = number_of_steps; // total number of steps for this motor
// Arduino pins for the motor control connection:
this->motor_pin_1 = motor_pin_1;
this->motor_pin_2 = motor_pin_2;
// setup the pins on the microcontroller:
pinMode(this->motor_pin_1, OUTPUT);
//pinMode(this->motor_pin_2, OUTPUT);
// Direction Pin
pinMode(this->direction_pin, OUTPUT);
this->direction_pin = dirPin;
// When there are only 2 pins, set the other two to 0:
// Only 1 motor_pin
this->motor_pin_2 = 0;
this->motor_pin_3 = 0;
this->motor_pin_4 = 0;
// pin_count is used by the stepMotor() method:
//this->pin_count = 2;
this->pin_count = 1;
* constructor for four-pin version
Stepper::Stepper(int number_of_steps, int motor_pin_1, int motor_pin_2, int motor_pin_3, int motor_pin_4)
this->motor_pin_3 = motor_pin_3;
this->motor_pin_4 = motor_pin_4;
pinMode(this->motor_pin_3, OUTPUT);
pinMode(this->motor_pin_4, OUTPUT);
this->pin_count = 4;
Sets the speed in revs per minute
void Stepper::setSpeed(long whatSpeed)
this->step_delay = 60L * 1000L / this->number_of_steps / whatSpeed;
Moves the motor steps_to_move steps. If the number is negative,
the motor moves in the reverse direction.
void Stepper::step(int steps_to_move)
int steps_left = abs(steps_to_move); // how many steps to take
// determine direction based on whether steps_to_mode is + or -:
if (steps_to_move > 0) {this->direction = 1;}
if (steps_to_move < 0) {this->direction = 0;}
// Attempt to write Direction
// set the dir digital pin as output:
pinMode(dirPin, OUTPUT);
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the dirPin is off turn it on and vice-versa:
if (this->direction == 1)
dirState = HIGH;
dirState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(dirPin, dirState);
if (this->direction == 1) {
digitalWrite(direction_pin, HIGH);
delay(1000); // wait for a second
digitalWrite(direction_pin, LOW);
// decrement the number of steps, moving one step each time:
while(steps_left > 0) {
// move only if the appropriate delay has passed:
if (millis() - this->last_step_time >= this->step_delay) {
// get the timeStamp of when you stepped:
this->last_step_time = millis();
// increment or decrement the step number,
// depending on direction:
this->step_number++;
if (this->step_number == this->number_of_steps) {
else {
if (this->step_number == 0) {
this->step_number = this->number_of_steps;
this->step_number--;
// decrement the steps left:
steps_left--;
// step the motor to step number 0, 1, 2, or 3:
stepMotor(this->step_number % 4);
* Moves the motor forward or backwards.
void Stepper::stepMotor(int thisStep)
if (this->pin_count == 1) {
// I think "switch" sets up a walk through each case.
switch (thisStep) {
case 0: /* 01 */
digitalWrite(motor_pin_1, LOW);
case 1: /* 11 */
digitalWrite(motor_pin_1, HIGH);
if (this->pin_count == 2) {
switch (thisStep) {
case 0: /* 01 */
digitalWrite(motor_pin_2, HIGH);
case 1: /* 11 */
case 2: /* 10 */
digitalWrite(motor_pin_2, LOW);
case 3: /* 00 */
if (this->pin_count == 4) {
switch (thisStep) {
case 0: // 1010
digitalWrite(motor_pin_3, HIGH);
digitalWrite(motor_pin_4, LOW);
case 1: // 0110
case 2: //0101
digitalWrite(motor_pin_3, LOW);
digitalWrite(motor_pin_4, HIGH);
case 3: //1001
version() returns the version of the library:
int Stepper::version(void)
return 4;
* MotorKnob
* A stepper motor follows the turns of a potentiometer
* (or other sensor) on analog input 0.
* http://www.arduino.cc/en/Reference/Stepper
* This example code is in the public domain.
//#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 100
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
// Pin 8 Steps and 10 Direction
Stepper stepper(STEPS, 8, 10);
// the previous reading from the analog input
int previous = 0;
// set the speed of the motor to 30 RPMs
stepper.setSpeed(30);
// get the sensor value
//int val = analogRead(0);
//Read analog 0 (pot) and map it to the range of the motor
int val = map(analogRead(0), 0, 1023, 400, 0);
// move a number of steps equal to the change in the
// sensor reading
stepper.step(val - previous);
// remember the previous value of the sensor
previous = val;
