MotorKnob Tutorial
I want to use a sharp IR range sensor to control a stepper motor using the code from the MotorKnob example in the Arduino library. The problem is when I turn on the arduino the stepper motor automatically starts turning a few times and then begins to turn according to the reading on the sensor (or potentiometer as used in the example). Why does this happen and is there a way to eliminate this issue?
The example:
The code:
 * MotorKnob
 * A stepper motor follows the turns of a potentiometer
 * (or other sensor) on analog input 0.
 * http://www.arduino.cc/en/Reference/Stepper
 * This example code is in the public domain.
#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 100
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
Stepper stepper(STEPS, 8, 9, 10, 11);
// the previous reading from the analog input
int previous = 0;
  // set the speed of the motor to 30 RPMs
  stepper.setSpeed(30);
  // get the sensor value
  int val = analogRead(0);
  // move a number of steps equal to the change in the
  // sensor reading
  stepper.step(val - previous);
  // remember the previous value of the sensor
  previous = val;
