Motors drive properly while using library with L298N driver, but no encoder values are picked up| Arduino Mega
Hi
I am trying to follow a tutorial from youtube on using ROS with arduino to control motors, and I have connected my L298N with battery exactly as the video describes and have uploaded the sketch with the supporting folder and it loads properly. The Arduino is powered properly via USB, but that connection is not shown in the diagram. When I type the "e" command, I get the proper response of "0 0" and when I do the "o 255 255" it says "OK" and drives properly but upon using "e" to check the encoders again I am getting the same "0 0". If anyone can spot something wrong with this, I would really appreciate the help in fixing it. Diagram and Code Below
#define USE_BASE      // Enable the base controller code
//#undef USE_BASE     // Disable the base controller code
/* Define the motor controller and encoder library you are using */
#ifdef USE_BASE
   /* The Pololu VNH5019 dual motor driver shield */
   //#define POLOLU_VNH5019
   /* The Pololu MC33926 dual motor driver shield */
   //#define POLOLU_MC33926
   /* The RoboGaia encoder shield */
   //#define ROBOGAIA
   /* Encoders directly attached to Arduino board */
   #define ARDUINO_ENC_COUNTER
   /* L298 Motor driver*/
   #define L298_MOTOR_DRIVER
#endif
//#define USE_SERVOS  // Enable use of PWM servos as defined in servos.h
#undef USE_SERVOS     // Disable use of PWM servos
/* Serial port baud rate */
#define BAUDRATE     57600
/* Maximum PWM signal */
#define MAX_PWM        255
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
/* Include definition of serial commands */
#include "commands.h"
/* Sensor functions */
#include "sensors.h"
/* Include servo support if required */
#ifdef USE_SERVOS
   #include <Servo.h>
   #include "servos.h"
#endif
#ifdef USE_BASE
  /* Motor driver function definitions */
  #include "motor_driver.h"
  /* Encoder driver function definitions */
  #include "encoder_driver.h"
  /* PID parameters and functions */
  #include "diff_controller.h"
  /* Run the PID loop at 30 times per second */
  #define PID_RATE           30     // Hz
  /* Convert the rate into an interval */
  const int PID_INTERVAL = 1000 / PID_RATE;
  /* Track the next time we make a PID calculation */
  unsigned long nextPID = PID_INTERVAL;
  /* Stop the robot if it hasn't received a movement command
   in this number of milliseconds */
  #define AUTO_STOP_INTERVAL 2000
  long lastMotorCommand = AUTO_STOP_INTERVAL;
#endif
/* Variable initialization */
// A pair of varibles to help parse serial commands (thanks Fergs)
int arg = 0;
int index = 0;
// Variable to hold an input character
char chr;
// Variable to hold the current single-character command
char cmd;
// Character arrays to hold the first and second arguments
char argv1[16];
char argv2[16];
// The arguments converted to integers
long arg1;
long arg2;
/* Clear the current command parameters */
void resetCommand() {
  cmd = NULL;
  memset(argv1, 0, sizeof(argv1));
  memset(argv2, 0, sizeof(argv2));
  arg1 = 0;
  arg2 = 0;
  arg = 0;
  index = 0;
/* Run a command.  Commands are defined in commands.h */
int runCommand() {
  int i = 0;
  char *p = argv1;
  char *str;
  int pid_args[4];
  arg1 = atoi(argv1);
  arg2 = atoi(argv2);
  switch(cmd) {
  case GET_BAUDRATE:
    Serial.println(BAUDRATE);
  case ANALOG_READ:
    Serial.println(analogRead(arg1));
  case DIGITAL_READ:
    Serial.println(digitalRead(arg1));
  case ANALOG_WRITE:
    analogWrite(arg1, arg2);
    Serial.println("OK");
  case DIGITAL_WRITE:
    if (arg2 == 0) digitalWrite(arg1, LOW);
    else if (arg2 == 1) digitalWrite(arg1, HIGH);
  case PIN_MODE:
    if (arg2 == 0) pinMode(arg1, INPUT);
    else if (arg2 == 1) pinMode(arg1, OUTPUT);
  case PING:
    Serial.println(Ping(arg1));
#ifdef USE_SERVOS
  case SERVO_WRITE:
    servos[arg1].setTargetPosition(arg2);
  case SERVO_READ:
    Serial.println(servos[arg1].getServo().read());
#endif
#ifdef USE_BASE
  case READ_ENCODERS:
    Serial.print(readEncoder(LEFT));
    Serial.print(" ");
    Serial.println(readEncoder(RIGHT));
   case RESET_ENCODERS:
    resetEncoders();
    resetPID();
  case MOTOR_SPEEDS:
    /* Reset the auto stop timer */
    lastMotorCommand = millis();
    if (arg1 == 0 && arg2 == 0) {
      setMotorSpeeds(0, 0);
      resetPID();
      moving = 0;
    else moving = 1;
    leftPID.TargetTicksPerFrame = arg1;
    rightPID.TargetTicksPerFrame = arg2;
  case MOTOR_RAW_PWM:
    resetPID();
    moving = 0; // Sneaky way to temporarily disable the PID
    setMotorSpeeds(arg1, arg2);
  case UPDATE_PID:
    while ((str = strtok_r(p, ":", &p)) != '\0') {
       pid_args[i] = atoi(str);
       i++;
    Kp = pid_args[0];
    Kd = pid_args[1];
    Ki = pid_args[2];
    Ko = pid_args[3];
#endif
  default:
    Serial.println("Invalid Command");
/* Setup function--runs once at startup. */
  Serial.begin(BAUDRATE);
// Initialize the motor controller if used */
#ifdef USE_BASE
  #ifdef ARDUINO_ENC_COUNTER
    //set as inputs
    DDRD &= ~(1<<LEFT_ENC_PIN_A);
    DDRD &= ~(1<<LEFT_ENC_PIN_B);
    DDRC &= ~(1<<RIGHT_ENC_PIN_A);
    DDRC &= ~(1<<RIGHT_ENC_PIN_B);
    //enable pull up resistors
    PORTD |= (1<<LEFT_ENC_PIN_A);
    PORTD |= (1<<LEFT_ENC_PIN_B);
    PORTC |= (1<<RIGHT_ENC_PIN_A);
    PORTC |= (1<<RIGHT_ENC_PIN_B);
    // tell pin change mask to listen to left encoder pins
    PCMSK2 |= (1 << LEFT_ENC_PIN_A)|(1 << LEFT_ENC_PIN_B);
    // tell pin change mask to listen to right encoder pins
    PCMSK1 |= (1 << RIGHT_ENC_PIN_A)|(1 << RIGHT_ENC_PIN_B);
    // enable PCINT1 and PCINT2 interrupt in the general interrupt mask
    PCICR |= (1 << PCIE1) | (1 << PCIE2);
  #endif
  initMotorController();
  resetPID();
#endif
/* Attach servos if used */
  #ifdef USE_SERVOS
    int i;
    for (i = 0; i < N_SERVOS; i++) {
      servos[i].initServo(
          servoPins[i],
          stepDelay[i],
          servoInitPosition[i]);
  #endif
/* Enter the main loop.  Read and parse input from the serial port
   and run any valid commands. Run a PID calculation at the target
   interval and check for auto-stop conditions.
  while (Serial.available() > 0) {
    // Read the next character
    chr = Serial.read();
    // Terminate a command with a CR
    if (chr == 13) {
      if (arg == 1) argv1[index] = NULL;
      else if (arg == 2) argv2[index] = NULL;
      runCommand();
      resetCommand();
    // Use spaces to delimit parts of the command
    else if (chr == ' ') {
      // Step through the arguments
      if (arg == 0) arg = 1;
      else if (arg == 1)  {
        arg = 2;
        index = 0;
      continue;
    else {
      if (arg == 0) {
        // The first arg is the single-letter command
        cmd = chr;
        // Subsequent arguments can be more than one character
        argv1[index] = chr;
        index++;
      else if (arg == 2) {
        argv2[index] = chr;
        index++;
// If we are using base control, run a PID calculation at the appropriate intervals
#ifdef USE_BASE
  if (millis() > nextPID) {
    updatePID();
    nextPID += PID_INTERVAL;
  // Check to see if we have exceeded the auto-stop interval
  if ((millis() - lastMotorCommand) > AUTO_STOP_INTERVAL) {;
    moving = 0;
#endif
// Sweep servos
#ifdef USE_SERVOS
  int i;
    servos[i].doSweep();
#endif
Rest of the code that comes with this is here, if it is important
ros_arduino_bridge/ROSArduinoBridge.ino at main · joshnewans/ros_arduino_bridge · GitHub):
Please post schematics, not a coloured bird nest with criss crossing lines. The physical shape of things is totally uninteresting. Pin designations are.
A link to the datasheet of the motor is also interesting.
Battery... That's a joke. No power fed to the controller...
It appears as a power problem but your frizzy picture is useless in determining what the problem is. Please post an annotated schematic with all power, grounds, and power sources shown. Also include links to "Technical Information" not sales information such as given on azon on the hardware items. Many look similar but are not. My suggestion for the L298N is to place it in the trash bin and replace with one that has a MOSFET output. You are losing about 2.8V of the 5V supply leaving only 2.2 Volts for the motor.
I have updated the schematic as both you and @gilshultz have recommended and attached links to the battery. Any help would be great!
No, You have not.
Don't expect helpers to follow tutorials or other videos. It consumes more time then most helpers will spend on any questioin.
Don't update the original post. That make the replies irrelevant. Post updates in Your following replies.
Still the same useless Fritzing, no pin designations, still not the entire code here.
There are to many other users that need help and are willing to put the energy into the schematics etc as we ask for it. It's a numbers game for me, I can go through what you have given us, take a guess and come back later and do it again. I only have a limited time each day. In that amount of time I can help maybe 5 others. Guess where I will be spending my time.
That is completely fair, and I really appreciate the effort you guys go to in donating your time. In response to @Railroader about the code, I wasn't sure which part of it was completely relevant but I included everything below.
This is the entire code for the main file:
#ifdef USE_BASE
   //#define ROBOGAIA
#endif
#define MAX_PWM        255
#else
#endif
#ifdef USE_SERVOS
   #include <Servo.h>
   #include "servos.h"
#endif
#ifdef USE_BASE
#endif
int arg = 0;
int index = 0;
char chr;
char cmd;
char argv1[16];
char argv2[16];
long arg1;
long arg2;
  cmd = NULL;
  arg1 = 0;
  arg2 = 0;
  arg = 0;
  index = 0;
int runCommand() {
  int i = 0;
  char *p = argv1;
  char *str;
  int pid_args[4];
  arg1 = atoi(argv1);
  arg2 = atoi(argv2);
  switch(cmd) {
  case GET_BAUDRATE:
  case ANALOG_READ:
  case DIGITAL_READ:
  case ANALOG_WRITE:
  case DIGITAL_WRITE:
  case PIN_MODE:
  case PING:
#ifdef USE_SERVOS
  case SERVO_WRITE:
  case SERVO_READ:
#endif
#ifdef USE_BASE
  case READ_ENCODERS:
    Serial.print(" ");
    resetEncoders();
    resetPID();
  case MOTOR_SPEEDS:
      resetPID();
      moving = 0;
    else moving = 1;
  case MOTOR_RAW_PWM:
    resetPID();
  case UPDATE_PID:
       i++;
    Kp = pid_args[0];
    Kd = pid_args[1];
    Ki = pid_args[2];
    Ko = pid_args[3];
#endif
  default:
#ifdef USE_BASE
    //set as inputs
  #endif
  resetPID();
#endif
  #ifdef USE_SERVOS
    int i;
          servoPins[i],
          stepDelay[i],
  #endif
    if (chr == 13) {
      runCommand();
      resetCommand();
        arg = 2;
        index = 0;
      continue;
    else {
      if (arg == 0) {
        cmd = chr;
        argv1[index] = chr;
        index++;
        argv2[index] = chr;
        index++;
#ifdef USE_BASE
    updatePID();
    moving = 0;
#endif
// Sweep servos
#ifdef USE_SERVOS
  int i;
#endif
Encoder Pin Designations:
   Encoder driver function definitions - by James Nugen
  //below can be changed, but should be PORTD pins;
  //otherwise additional changes in the code are required
  #define LEFT_ENC_PIN_A PD2  //pin 2
  #define LEFT_ENC_PIN_B PD3  //pin 3
  //below can be changed, but should be PORTC pins
  #define RIGHT_ENC_PIN_A PC4  //pin A4
  #define RIGHT_ENC_PIN_B PC5   //pin A5
#endif
long readEncoder(int i);
void resetEncoder(int i);
void resetEncoders();
Encoder Driver:
   Encoder definitions
   Add an "#ifdef" block to this file to include support for
   a particular encoder board or library. Then add the appropriate
   #define near the top of the main ROSArduinoBridge.ino file.
#ifdef USE_BASE
#ifdef ROBOGAIA
  /* The Robogaia Mega Encoder shield */
  #include "MegaEncoderCounter.h"
  /* Create the encoder shield object */
  MegaEncoderCounter encoders = MegaEncoderCounter(4); // Initializes the Mega Encoder Counter in the 4X Count mode
  /* Wrap the encoder reading function */
  long readEncoder(int i) {
    if (i == LEFT) return encoders.YAxisGetCount();
    else return encoders.XAxisGetCount();
  /* Wrap the encoder reset function */
  void resetEncoder(int i) {
    if (i == LEFT) return encoders.YAxisReset();
    else return encoders.XAxisReset();
#elif defined(ARDUINO_ENC_COUNTER)
  volatile long left_enc_pos = 0L;
  volatile long right_enc_pos = 0L;
  static const int8_t ENC_STATES [] = {0,1,-1,0,-1,0,0,1,1,0,0,-1,0,-1,1,0};  //encoder lookup table
  /* Interrupt routine for LEFT encoder, taking care of actual counting */
  ISR (PCINT2_vect){
  	static uint8_t enc_last=0;
	enc_last <<=2; //shift previous state two places
	enc_last |= (PIND & (3 << 2)) >> 2; //read the current state into lowest 2 bits
  	left_enc_pos += ENC_STATES[(enc_last & 0x0f)];
  /* Interrupt routine for RIGHT encoder, taking care of actual counting */
  ISR (PCINT1_vect){
	enc_last |= (PINC & (3 << 4)) >> 4; //read the current state into lowest 2 bits
  	right_enc_pos += ENC_STATES[(enc_last & 0x0f)];
    if (i == LEFT) return left_enc_pos;
    else return right_enc_pos;
    if (i == LEFT){
      left_enc_pos=0L;
      return;
      right_enc_pos=0L;
      return;
#else
  #error A encoder driver must be selected!
#endif
void resetEncoders() {
  resetEncoder(LEFT);
  resetEncoder(RIGHT);
#endif
Nice but not the frizzy picture. They look nice on documentation but are useless for problem solving.
You just don't get it. I fully agree with @ gilshultz. in reply #6.
No more time will be spent on Your question.
I saw a classic Nano in the video.
The code could use interrupts or port manipulation, which is different on a Mega.
Leo..
What would you recommend for changing the pins to? I would think it could be problem with not having an interrupt pin, but D3 is an interrupt pin and neither side of the encoder is reporting so it doesn't make a lot of sense to me.
Don't know. Study the library code.
Why don't you simply use the same hardware as the example.
What are actually the encoder pins used with the Nano with two motors.
Pin2 and pin3 and ...?
External interrupt on a Nano is only on pin 2, 3.
On a Mega it't pin 2, 3, 18, 19, 20, 21.
Leo..
