Motors in quadrocopter problem after adding radio control.
Hello everyone. This is my first topic so please be forgiving:)
As in topic i have a problem with motors. I'm developing my own flight control software to quadrocopter on Arduino Mega. Everything worked as intended until i add radio control. I'm using pin interrupt method. Without this motors are working really smooth, but with rc they are not. Their speed jump up and down just for a split second. Different motors in random time. With such problem i can't config PID. Here is my code responsible for rc:
double ch1val = 0;
double ch2val = 0;
double ch3val = 0;
double ch4val = 0;
int ch1time = 0;
int ch2time = 0;
int ch3time = 0;
int ch4time = 0;
void ch1IntEnd() {
  if (digitalRead(ch1)==HIGH){
    ch1time = micros();
    ch1time = micros()-ch1time;
    int ch1val = map(ch1time,970,1980,0,100);
    ch1val = ch1val/2;
    setBaseVal(60+ch1val);
  if (ch1time<1000) {
    PIDenabled = false;
    PIDenabled = true;
void ch2IntEnd() {
  if (digitalRead(ch2)==HIGH){
    ch2time = micros();
    ch2time = micros()-ch2time;
    int ch2val = map(ch2time,892,1900,-50,50);
    ch2val = ch2val/5;
    setPowerYaw(ch2val);
void ch3IntEnd() {
  if (digitalRead(ch3)==HIGH){
    ch3time = micros();
    ch3time = micros()-ch3time;
    int ch3val = map(ch3time,970,1980,-50,50);
    ch3val = ch3val/10;
    setPowerPitch(ch3val);
void ch4IntEnd() {
  if (digitalRead(ch4)==HIGH){
    ch4time = micros();
    ch4time = micros()-ch4time;
    int ch4val = map(ch4time,970,1980,-50,50);
    ch4val = ch4val/10;
    setPowerRoll(ch4val);
attachInterrupt is in other function. It looks like this:
attachInterrupt(0, ch1IntEnd, CHANGE);
attachInterrupt(1, ch2IntEnd, CHANGE);
attachInterrupt(5, ch3IntEnd, CHANGE);
attachInterrupt(4, ch4IntEnd, CHANGE);
Does anyone have any idea what can cause the problem? If so i'll be grateful for any help.
I suspect that the problem is that your ISR's which you are using to decode the PWM from the RC receiver are taking too much time and are screwing up the output PWM for the motors
I'm no expert, but if you look at the APM board (DIYDrones), it uses a dedicated ATMega328 just to do the PWM I think.
I presume this is because its too much for the Mega to process in the available time.
Apart from asking why you'd want to make your own software for this, ie its been done loads of time already, so there is generally no point writing it from scratch yourself...
You could try either optimizing your RC decode ISR's. But I suspect your best bet is to switch to a faster processor.
Maple mini clones operate at 72Mhz and are only around $5 on eBay and AliExpress and there is a now a Beta port of the 1.6.rc1 IDE to support this (see the micro controllers forum)
Alternatively the Teensy is a bit faster again than the Maple mini's so you could look at using that instead (albeit its $19 + postage and postage can be expensive for this if you are outside the USA)
if you intend to change values in interrupts, declare them volatile.
like this
volatile int ch1time = 0;
and here is an example, the interrupt uses a different method, but basically is the same.
// MultiChannels
// rcarduino.blogspot.com
// A simple approach for reading three RC Channels using pin change interrupts
// See related posts -
// http://rcarduino.blogspot.co.uk/2012/01/how-to-read-rc-receiver-with.html
// http://rcarduino.blogspot.co.uk/2012/03/need-more-interrupts-to-read-more.html
// http://rcarduino.blogspot.co.uk/2012/01/can-i-control-more-than-x-servos-with.html
// include the pinchangeint library - see the links in the related topics section above for details
#include <PinChangeInt.h>
#include <Servo.h>
// Assign your channel in pins
#define THROTTLE_IN_PIN 8
#define STEERING_IN_PIN 9
#define AUX_IN_PIN 10
// Assign your channel out pins
#define THROTTLE_OUT_PIN 5
#define STEERING_OUT_PIN 6
#define AUX_OUT_PIN 7
// Servo objects generate the signals expected by Electronic Speed Controllers and Servos
// We will use the objects to output the signals we read in
// this example code provides a straight pass through of the signal with no custom processing
Servo servoThrottle;
Servo servoSteering;
Servo servoAux;
// These bit flags are set in bUpdateFlagsShared to indicate which
// channels have new signals
#define THROTTLE_FLAG 1
#define STEERING_FLAG 2
#define AUX_FLAG 4
// holds the update flags defined above
volatile uint8_t bUpdateFlagsShared;
// shared variables are updated by the ISR and read by loop.
// In loop we immediatley take local copies so that the ISR can keep ownership of the
// shared ones. To access these in loop
// we first turn interrupts off with noInterrupts
// we take a copy to use in loop and the turn interrupts back on
// as quickly as possible, this ensures that we are always able to receive new signals
volatile uint16_t unThrottleInShared;
volatile uint16_t unSteeringInShared;
volatile uint16_t unAuxInShared;
// These are used to record the rising edge of a pulse in the calcInput functions
// They do not need to be volatile as they are only used in the ISR. If we wanted
// to refer to these in loop and the ISR then they would need to be declared volatile
uint32_t ulThrottleStart;
uint32_t ulSteeringStart;
uint32_t ulAuxStart;
  Serial.println("multiChannels");
  // attach servo objects, these will generate the correct
  // pulses for driving Electronic speed controllers, servos or other devices
  // designed to interface directly with RC Receivers
  servoThrottle.attach(THROTTLE_OUT_PIN);
  servoSteering.attach(STEERING_OUT_PIN);
  servoAux.attach(AUX_OUT_PIN);
  // using the PinChangeInt library, attach the interrupts
  // used to read the channels
  PCintPort::attachInterrupt(THROTTLE_IN_PIN, calcThrottle,CHANGE);
  PCintPort::attachInterrupt(STEERING_IN_PIN, calcSteering,CHANGE);
  PCintPort::attachInterrupt(AUX_IN_PIN, calcAux,CHANGE);
  // create local variables to hold a local copies of the channel inputs
  // these are declared static so that thier values will be retained
  // between calls to loop.
  static uint16_t unThrottleIn;
  static uint16_t unSteeringIn;
  static uint16_t unAuxIn;
  // local copy of update flags
  static uint8_t bUpdateFlags;
    Serial.print(F("CHANNAL1--"));
    Serial.print(unThrottleIn);
    Serial.print(F(" CHANNAL2--"));
    Serial.println(unSteeringIn);
  // check shared update flags to see if any channels have a new signal
  if(bUpdateFlagsShared)
    noInterrupts(); // turn interrupts off quickly while we take local copies of the shared variables
    // take a local copy of which channels were updated in case we need to use this in the rest of loop
    bUpdateFlags = bUpdateFlagsShared;
    // in the current code, the shared values are always populated
    // so we could copy them without testing the flags
    // however in the future this could change, so lets
    // only copy when the flags tell us we can.
    if(bUpdateFlags & THROTTLE_FLAG)
      unThrottleIn = unThrottleInShared;
    if(bUpdateFlags & STEERING_FLAG)
      unSteeringIn = unSteeringInShared;
    if(bUpdateFlags & AUX_FLAG)
      unAuxIn = unAuxInShared;
    // clear shared copy of updated flags as we have already taken the updates
    // we still have a local copy if we need to use it in bUpdateFlags
    bUpdateFlagsShared = 0;
    interrupts(); // we have local copies of the inputs, so now we can turn interrupts back on
    // as soon as interrupts are back on, we can no longer use the shared copies, the interrupt
    // service routines own these and could update them at any time. During the update, the
    // shared copies may contain junk. Luckily we have our local copies to work with :-)
  // do any processing from here onwards
  // only use the local values unAuxIn, unThrottleIn and unSteeringIn, the shared
  // variables unAuxInShared, unThrottleInShared, unSteeringInShared are always owned by
  // the interrupt routines and should not be used in loop
  // the following code provides simple pass through
  // this is a good initial test, the Arduino will pass through
  // receiver input as if the Arduino is not there.
  // This should be used to confirm the circuit and power
  // before attempting any custom processing in a project.
  // we are checking to see if the channel value has changed, this is indicated
  // by the flags. For the simple pass through we don't really need this check,
  // but for a more complex project where a new signal requires significant processing
  // this allows us to only calculate new values when we have new inputs, rather than
  // on every cycle.
    if(servoThrottle.readMicroseconds() != unThrottleIn)
      servoThrottle.writeMicroseconds(unThrottleIn);
    if(servoSteering.readMicroseconds() != unSteeringIn)
      servoSteering.writeMicroseconds(unSteeringIn);
    if(servoAux.readMicroseconds() != unAuxIn)
      servoAux.writeMicroseconds(unAuxIn);
  bUpdateFlags = 0;
// simple interrupt service routine
void calcThrottle()
  // if the pin is high, its a rising edge of the signal pulse, so lets record its value
  if(digitalRead(THROTTLE_IN_PIN) == HIGH)
    ulThrottleStart = micros();
    // else it must be a falling edge, so lets get the time and subtract the time of the rising edge
    // this gives use the time between the rising and falling edges i.e. the pulse duration.
    unThrottleInShared = (uint16_t)(micros() - ulThrottleStart);
    // use set the throttle flag to indicate that a new throttle signal has been received
    bUpdateFlagsShared |= THROTTLE_FLAG;
void calcSteering()
  if(digitalRead(STEERING_IN_PIN) == HIGH)
    ulSteeringStart = micros();
    unSteeringInShared = (uint16_t)(micros() - ulSteeringStart);
    bUpdateFlagsShared |= STEERING_FLAG;
void calcAux()
  if(digitalRead(AUX_IN_PIN) == HIGH)
    ulAuxStart = micros();
    unAuxInShared = (uint16_t)(micros() - ulAuxStart);
    bUpdateFlagsShared |= AUX_FLAG;
Thank you guys for help. I will check on your advice.
rogerClark i know that there is plenty of ready software, but i want to make my own as a challenge:) Also thanks for info about boards Maple mini and Teensy, but i'm going to borrow Arduino Due. It has 84 MHz clock speed.
To be honest, check your batteries in your Tx. Whenever they start to die in my Tx, my controls get twitchy.
