Motors spins in half of all speed
Hi everyone :slight_smile:
My motors is connected to motor shield, and motor shield is mounted on arduio MEGA.
When in code I send HIGH to motors (5 volts), motors spins, but in half speed. Some months ago, motors spins really fastly, so a the robot "flyed" in my house, but now it rides really slowly, really.
Can anyone help?
syvanaLTU:
If you have changed absolutely nothing since the time it was working properly it seems likely that the battery is discharged or a connection somewhere has deteriorated (perhaps corroded or worked loose).
If you have changed something (however trivial it may seem) you need to give us all the details.
...R
I don't changed anything, exept arduino (from UNO to MEGA).
syvanaLTU:
It's time to post code and schematics....
Any chance your output control has changed from 5v to 3v3
syvanaLTU:
I would not describe that as "don't changed anything". That is a very BIG change.
Post your code and a diagram showing how everything is connected. A photo of a clear pencil drawing will be fine.
...R
What motor shield? At 5V you'll need a MOSFET H-bridge to avoid massive losses
of the L298 and L293D's at low supply voltage.
Or is 5V only the logic supply?
More details please - ie all the relevant details so we can understand what you have there...
