Motors turn off at the press of 4 buttons
Hello there,
I was wondering if you could please help me ?
I am using Processing 2 software to control the direction of rotation of 6v motors connected to a Motor Shield v1.2 on an Arduino Uno.
I want to turn off (RELEASE) the motor when only all 4 push buttons are pressed. However it doesn’t work!
I have made a series circuit of all the push buttons with a resistor and a signal line coming from one of the pins on the push button to signal when they are all pushed and a HIGH signal is sent to Pin 2 on the motor shield.
This is the code :
#include <AFMotor.h>
const int buttonPin = 2;
int buttonState = 0;
const int PressureSensor1 = 1;
int val= 0;
const int TURNOFFPRESSURE1 =754;
int incomingByte;
AF_DCMotor motor(1, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
//aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println(“Motor test!”);
//bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
void loop() { //
pinMode(buttonPin, INPUT);
if (Serial.available() > 0) {
// read the oldest byte in the serial buffer:
incomingByte = Serial.read();
Serial.println(val);
if (incomingByte == ‘w’) {
Serial.print(“extension”);
val = analogRead(PressureSensor1);
if (val <TURNOFFPRESSURE1)
motor.run(FORWARD); // turn it on going forward
else {
motor.run(RELEASE); // stopped
if (incomingByte == ‘s’) {
motor.run(RELEASE);
if (incomingByte == ‘x’) { // This is the problem area!!!
Serial.print(“retraction”);
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
if (buttonState == HIGH) {
digitalWrite(ledPin, HIGH);
motor.run(RELEASE);
else {
motor.run(BACKWARD);
const int ledPin = 13;
int val= 0;
int incomingByte;
// const int PressureSensor2 = 1;
// int val2= 0;
// const int TURNOFFPRESSURE2 =754;
// int incomingByte2;
// AF_DCMotor motor2(4, MOTOR12_1KHZ); // create motor #2, 64KHz pwm
//aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
motor.setSpeed(255); // set the speed to 200/255
// motor2.setSpeed(255); // set the speed to 200/255
//bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
void loop() { ///hg4
pinMode(ledPin, OUTPUT);
if (Serial.available() > 0) { //ws2
if (incomingByte == ‘w’) { //df1
else { //gf2
} //gf2
} //df1
if (incomingByte == ‘s’) { //h12
motor.run(RELEASE);
} //h12
if (incomingByte == ‘x’) { //po8
if (buttonState == HIGH) { //5R5
motor.run(RELEASE);
} //5R5
else { //D411
} //D411
} //po8
} //ws2
} //hg4
Any help would be much appreciated !
Thank you
Calum
You only sense the button at the exact moment the 'x' is read - is that the intention?
BTW please edit your post to use // code tags - the icon to the left of the
quote icon... Then I might be able to follow your indentation even!
I want to turn off (RELEASE) the motor when only all 4 push buttons are pressed. However it doesn't work!
Are these buttons on your PC screen or are they hardware buttons directly connected to your Arduino?
...R
Can you please post a copy of your sketch, using code tags?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom.... :slight_smile:
