Hi there - thanks for reading!
So I have an arduino uno with an adafruit motor shield running two stepper motors and a servo. The steppers are 28BYJ-48 5V DC. The servo is a micro servo.
I am controlling this through a) my hacked TV remote sending hex codes to an IR receiver and b) a processing sketch sending serial information.
My problem still occurs regardless of whether I’m powering the system through either USB or external power.
The problem is that this entire system used to work perfectly. Now it doesn’t. At all. Literally within a single minute it went from working completely to not responding in all cases.
The servo responds by moving to angle 100 when I start up the system - but won’t respond to anything after that. At one point, only the servo would respond - now…nothing.
I haven’t changed anything, I’ve re-uploaded the same code a few times. I’m at a loss. I don’t have good enough income to just buy a new arduino or motor shield, so I’m really hoping I haven’t blown the system.
I’ve attached some pictures and will c + p the code below.
Has this ever happened to you? If so, what was the problem and how did you solve it? Have I blown my equipment somehow?
NOTE: Most of the code used in this project depicts how the system will react to input from either processing or my TV remote, so there’s a lot of repeating information, and a lot of it won’t seem relevant.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
#include "IRremote.h"
#include <Stepper.h>
#include <Servo.h>
const int STEPS = 32; // Number of steps per revolution of Internal shaft
int receiver = 6; // Signal Pin of IR receiver to Arduino Digital Pin 6
int dir;
int angle = 0;
#define UP 0xFE609F
#define DOWN 0xFEE01F
#define LEFT 0xFE827D
#define RIGHT 0xFEC23D
#define OPEN 0xFEE21D
#define CLOSED 0xFE847B
#define speedOneHundred 0xFE8877
#define speedTwoHundred 0xFE48B7
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *stepperLR = AFMS.getStepper(200, 1);
Adafruit_StepperMotor *stepperUD = AFMS.getStepper(200, 2);
Servo servo;
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
irrecv.enableIRIn(); // Start the receiver
AFMS.begin(); // create with the default frequency 1.6KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
stepperLR->setSpeed(200);
stepperUD->setSpeed(200);
servo.attach(10);
servo.write(100);
if (irrecv.decode(&results)) // have we received an IR signal?
Serial.println(results.value);
Serial.println(results.value,HEX);
irrecv.resume();
if(results.value == UP){
dir = 1;
stepperUD->step(50,FORWARD,DOUBLE);
else if(results.value == 4294967295 && dir == 1){
else if(results.value == DOWN){
dir = -1;
stepperUD->step(50,BACKWARD,DOUBLE);
else if(results.value == 4294967295 && dir == -1){
else if(results.value == LEFT){
dir = 2;
stepperLR->step(100,FORWARD,DOUBLE);
else if (results.value == 4294967295 && dir == 2)
stepperLR->step(50, FORWARD, DOUBLE);
else if(results.value == RIGHT){
dir = -2;
stepperLR->step(100,BACKWARD,DOUBLE);
else if (results.value == 4294967295 && dir == -2)
stepperLR->step(50, BACKWARD, DOUBLE);
else if(results.value == OPEN){
dir = 0;
servo.write(100);
}else if(results.value == CLOSED){
dir = 0;
servo.write(75);
else { dir = 0; }
else if(Serial.available() > 0){
char buttonPress = Serial.read();
if(buttonPress == '0'){
stepperUD->step(5,FORWARD,DOUBLE);
else if(buttonPress == '1'){
stepperUD->step(5,BACKWARD,DOUBLE);
else if(buttonPress == '2'){
stepperLR->step(5,FORWARD,DOUBLE);
else if(buttonPress == '3'){
stepperLR->step(5,BACKWARD,DOUBLE);
if(buttonPress == '4'){
else if(buttonPress == '5'){
else if(buttonPress == '6'){
stepperLR->step(50,FORWARD,DOUBLE);
else if(buttonPress == '7'){
stepperLR->step(50,BACKWARD,DOUBLE);
else if(buttonPress == 'a'){
stepperLR->setSpeed(50);
else if(buttonPress == 'b'){
stepperLR->setSpeed(100);
else if(buttonPress == 'c'){
else if(buttonPress == 'd'){
stepperUD->setSpeed(50);
else if(buttonPress == 'e'){
stepperUD->setSpeed(100);
else if(buttonPress == 'f'){
else if(buttonPress == 'g'){
else if(buttonPress == 'h'){
stepperUD->step(100,FORWARD,DOUBLE);
stepperUD->step(100,BACKWARD,DOUBLE);
else if(buttonPress == 'i'){
stepperLR->step(500,BACKWARD,DOUBLE);
stepperLR->step(500,FORWARD,DOUBLE);
else if(buttonPress == 'j'){
servo.write(100);
else if(buttonPress == 'k'){
servo.write(75);
