Motors
I am making a Ardunio robot it’s going to reasonably heavy. 15 pounds at Maximum
I was wondering which one of these motors/frame would be better
My robot does not need to go very fast but I’d like it to go about half speed of average person walking
frame/motor 1
http://www.bizoner.com/arduino-2wd-acrylic-robot-platform-2-wheel-drive-mobile-chassis-p-297.html
frame/motor 2
http://www.diybin.com/products/DFRobot-4WD-Mobile-Platform-Arduino-CONTROLLER.html
if you think that these both will not work then please give me links to better ones.
I also need help with finding wheels if the above two are not suitable.
Can someone find robotic wheels for the below motor,I'm not good with the measurements . just in case the above products cant lug 15 pounds around
Tough Gear Motor: Small but durable. Measures 2-7/16" long x 1-5/16" dia. and has a 3/16" x 3/8" long flattened offset shaft. Runs between 6-12 VDC. At 12 VDC, it spins 7 rpm and draws 90mA with a 500mA stall current. Gearbox ratio is approx 400:1. Has (3) 3/32" mounting holes on the shaft face. Reversible.
can anyone provide insight?
