Hey I have a question. I have a Motorshield V1.2 + 28BYJ-48 Stepper.
I connected them following:
Motor---Shield
Red Wire -GND
Orange - Top clamp M1
Yellow - Bottom Clamp M2
Pink -Bottom Clamp M1
Blue - Top Clamp M2
With the followed code that I have from AdaFruit
Skip to content
Features
Business
Explore
Marketplace
Pricing
This repository
Search
Sign in or Sign up
60 216 181 adafruit/Adafruit-Motor-Shield-library
Code Issues 6 Pull requests 0 Projects 0 Insights
Adafruit-Motor-Shield-library/examples/AFMotor_MultiStepper/AFMotor_MultiStepper.pde
d2ffa19 on 23 Feb 2011
@ladyada ladyada added accelstepper examples, fixed casting problem for stepper timing
57 lines (48 sloc) 1.41 KB
// MultiStepper
// -*- mode: C++ -*-
// Control both Stepper motors at the same time with different speeds
// and accelerations.
// Requires the AFMotor library (https://github.com/adafruit/Adafruit-Motor-Shield-library)
// And AccelStepper with AFMotor support (https://github.com/adafruit/AccelStepper)
// Public domain!
#include <AccelStepper.h>
#include <AFMotor.h>
// two stepper motors one on each port
AF_Stepper motor1(200, 1);
AF_Stepper motor2(200, 2);
// you can change these to DOUBLE or INTERLEAVE or MICROSTEP!
// wrappers for the first motor!
void forwardstep1() {
motor1.onestep(FORWARD, SINGLE);
void backwardstep1() {
motor1.onestep(BACKWARD, SINGLE);
// wrappers for the second motor!
void forwardstep2() {
motor2.onestep(FORWARD, SINGLE);
void backwardstep2() {
motor2.onestep(BACKWARD, SINGLE);
// Motor shield has two motor ports, now we'll wrap them in an AccelStepper object
AccelStepper stepper1(forwardstep1, backwardstep1);
AccelStepper stepper2(forwardstep2, backwardstep2);
stepper1.setMaxSpeed(200.0);
stepper1.setAcceleration(100.0);
stepper1.moveTo(24);
stepper2.setMaxSpeed(300.0);
stepper2.setAcceleration(100.0);
stepper2.moveTo(1000000);
// Change direction at the limits
if (stepper1.distanceToGo() == 0)
stepper1.moveTo(-stepper1.currentPosition());
stepper1.run();
stepper2.run();
But it dosnot work what am I doing wrong??
