motorspeed1 not declared in this scope
hello i am 9yrs old and i am trying to build a robot but i get an error message at the end. can somebody help me
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Jim\Documents\Arduino\motorandjoystick\motor_and_joystick\motor_and_joystick.ino: In function 'void loop()':
motor_and_joystick:95:5: error: 'MotorSpeed1' was not declared in this scope
MotorSpeed1 = map(joyposVert, 0, 460, 0, 255);
motor_and_joystick:96:5: error: 'MotorSpeed2' was not declared in this scope
MotorSpeed2 = map(joyposVert, 0, 460, 0, 255);
motor_and_joystick:115:5: error: 'MotorSpeed1' was not declared in this scope
MotorSpeed1 = map(joyposVert, 564, 1023, 0, 255);
motor_and_joystick:116:5: error: 'MotorSpeed2' was not declared in this scope
MotorSpeed2 = map(joyposVert, 564, 1023, 0, 255);
motor_and_joystick:126:5: error: 'MotorSpeed1' was not declared in this scope
MotorSpeed1 = 0;
motor_and_joystick:127:5: error: 'MotorSpeed2' was not declared in this scope
MotorSpeed2 = 0;
motor_and_joystick:146:22: error: 'joyposHorze' was not declared in this scope
joyposHorz = map(joyposHorze, 0, 460, 0, 255);
motor_and_joystick:149:5: error: 'MotorSpeed1' was not declared in this scope
MotorSpeed1 = MotorSpeed1 - joyposHorz;
motor_and_joystick:150:5: error: 'MotorSpeed2' was not declared in this scope
MotorSpeed2 = MotorSpeed2 + joyposHorz;
motor_and_joystick:167:5: error: 'MotorSpeed1' was not declared in this scope
MotorSpeed1 = MotorSpeed1 + joyposHorz;
motor_and_joystick:169:5: error: 'MotorSpeed2' was not declared in this scope
MotorSpeed2 = MotorSpeed2 - joyposHorz;
motor_and_joystick:182:20: error: 'MotorSpeed1' was not declared in this scope
analogWrite(ENA, MotorSpeed1);
motor_and_joystick:184:20: error: 'MotorSpeed2' was not declared in this scope
analogWrite(ENB, MotorSpeed2);
exit status 1
option enabled in File -> Preferences.
// Motor A
int ENA = 9;
int in1 = 8;
int in2 = 7;
// Motor B
int ENB = 3;
int in3 = 5;
int in4 = 4;
// Joystick Input
int joyVert = A0; // vertical
int joyHorz = A1; // Horizontal
// Motor speed values - start at zero
int Motorspeed1 = 0;
int Motorspeed2 = 0;
// joystick values - start at 512 (middle position)
int joyposVert = 512;
int joyposHorz = 512;
// set all the motor control pins to outputs
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Start with motors disabled and direction forward
// Motor A
digitalWrite(ENA, LOW);
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Motor B
digitalWrite(ENB, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Read the joystick x and y positions
joyposVert = analogRead(joyVert);
joyposHorz = analogRead(joyHorz);
// Determine if this is a forward or backward motion
// Do this by reading the vertical value
// Apply results to MotorSpeed and to direction
if (joyposVert < 460)
// This is Backward
// Set Motor A backward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Motor B backward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
// Determine MotorSpeeds
// As we are going backwards we need to reverse readings
joyposVert = joyposVert - 460; // This produces a negative number
joyposVert = joyposVert * -1; // Make the number positive
else if (joyposVert > 564)
// This is Forward
// Set Motor A forward
// Set Motor B forward
//Determine Motor Speeds
// This is Stopped
MotorSpeed1 = 0;
MotorSpeed2 = 0;
// Now do the steering
// The Horizontal position will "weigh" the motor
// Values for each motor
if (joyposHorz < 460)
// Move Left
// As we are going left we need to reverse readings
joyposHorz = joyposHorz - 460; // This produces a negative number
joyposHorz = joyposHorz * -1; // Make the number positive
// Map the number to a value of 255 maximum
// Don`t exceed range of 0-255 for motor speeds
if (MotorSpeed1 < 0)MotorSpeed1 = 0;
if (MotorSpeed2 > 255)MotorSpeed2 = 255;
else if (joyposHorz > 564)
// Move Right
joyposHorz = map(joyposHorz, 564, 1023, 0, 255);
// Don`t exceed range 0-255 for motor speeds
if (MotorSpeed1 > 255)MotorSpeed1 = 255;
if (MotorSpeed2 < 0)MotorSpeed2 = 0;
// Set the motor speeds
Post your sketch. Please use code tags.
You should share your code if you want help. In your IDE you can use "copy for forum" under the edit menu. Or you can copy and paste it between code tags. [code]your code here[/code]
Either those variables are not defined or they are defined as local variables inside a different function. Remember, capitalization counts. Declaring "motorSpeed1" doesn't declare "MotorSpeed1".
If they are used in only one function, declare them in the one function. If they are shared between two or more functions, declare them outside of any function and somewhere above the first function they are used in.
Blackfin:
// Motor A
int ENA = 9;
int in1 = 8;
int in2 = 7;
// Motor B
int ENB = 3;
int in3 = 5;
int in4 = 4;
// Joystick Input
// Motor A
// Motor B
// This is Backward
// Motor B backward
// This is Forward
// This is Stopped
MotorSpeed1 = 0;
MotorSpeed2 = 0;
// Move Left
// Move Right
As johnwasser notes, spelling and capitalization matter. You declare:
but reference (for example):
Do you see the difference?
You quote a line that says to use code tags and then disregard using code tags. Smh
I just don't understand people.
DangerToMyself:
What the ???
The OP said he/she is 9 yrs old. Assuming this to be true, I think we can cut them some slack.
